anyone replace the water pump? - Insight Central: Honda Insight Forum
Old 12-05-2012, 08:42 PM   #1 (permalink)
Gadget01's Avatar
Default anyone replace the water pump?
My Insight makes an awful whine noise that varies with engine rpm's. I'm 99% certain it's the water pump. Anyone have experience with this?
Gadget01 is offline   Reply With Quote
Old 12-05-2012, 10:06 PM   #2 (permalink)
Check the idler (tension) pully for the serpentine belt.
Use: 321,000 mi. @ 57.8 LMPG
07 FIT "S"
(3K made, The prototype one?)
Old 12-05-2012, 11:09 PM   #3 (permalink)
Get an automotive stethoscope from autozone, harbor freight. It'll be easy to tell where exactly the sound is coming from.
Sent from my DROID RAZR using AutoGuide.Com Free App
2001 Silver M/T
-EGR mod by Jeff652
-Grid charger by Jeff652
GChamb is offline   Reply With Quote
Old 12-06-2012, 06:51 AM   #4 (permalink)
Ditto. idler
Old 12-06-2012, 12:50 PM   #5 (permalink)
TopFuelTim's Avatar
Mine was the idler too. It takes a regular bearing (about $5), if you have access to a press.
Tim
Old 12-06-2012, 01:15 PM   #6 (permalink)
Top, can you post the bearing number here? It would be helpful.
Old 12-06-2012, 06:53 PM   #7 (permalink)
TopFuelTim's Avatar
Default no problem - 6203 - 2RS
Be glad to. It uses a common 6203-2RS bearing. The factory bearing has NSK 6203 DUL1 embossed on the seal. Do yourself a favor and buy a quality bearing, however. I work at a manufacturing plant, and occasionally some cheap bearings get past engineering, which creates a bit of havoc in the field.
My 0.02 cents worth,
Tim Glover
Old 12-08-2012, 04:58 PM   #8 (permalink)
whereswally606's Avatar
I have had exactly the same issue a week ago. the issue was indeed a bearing in the idler tension pulley, water pump had a little play but was not causing the noise. Have spent £126 on a new honda water pump which is now fitted and £5 on the bearing for the tensioner which we pressed out at my mechanics garage.
Have the old water pump which is really probably fine and im guessing would be as new if the bearing in it was replaced too. Anyone on here need one? open to offers.
Also i think ive lost 20mpg from 70 to 50 from when i got the new waterpump fitted and can this be caused by an over tensioned belt?
Andy drives
Rufio, a Citrus Burst Yellow 51 plate 100+k miles.
MODS:
Mima 152P, Winter only Radiator Block, BCM gauge, SGII, LG stereo 4x53W, upgraded stock honda 20W speakers and pioneer 180W rear speakers, 350mA Grid Charger
whereswally606 is offline   Reply With Quote
Old 12-08-2012, 05:44 PM   #9 (permalink)
Yes! The design of the belt doesn't dictate it to be "really taunt".
07 FIT "S"
Old 12-08-2012, 09:31 PM   #10 (permalink)
olrowdy01's Avatar
Old school method: Use a small diameter vacuum hose, stick one end of the hose in your ear and hold the other end on the suspected noise area. I also use a very small metal funnel on the engine end of the hose.
2005 Insight, MT, 88K, Silver
1988 Honda CRX HF, 44/51 mpg
1963 Lotus 7 replica, 12 mpg
http://dmr-architect.com/~locouki/
olrowdy01 is offline   Reply With Quote
