Dash background light out - Insight Central: Honda Insight Forum
Old 12-20-2012, 04:39 PM   #1 (permalink)
Default Dash background light out
All my warning lights come on and off and usual when starting so no problem with them. However I can't see any of the LED displays unless I shine a light on them or there is sunlight (speedometer, charge, discharge, gasoline, etc.). No other problems that I can detect. The brightness control does nothing. Is this backlight fuse protected?
astrolink is offline   Reply With Quote
Old 12-20-2012, 06:09 PM   #2 (permalink)
check the #15 fuse under the dash. should be a 10amp. i
ac
295,000miles
Old 01-24-2013, 07:37 PM   #3 (permalink)
Any idea about like the mode and Econ button? They are not lighting up?
Sent from AutoGuide.com App
drewbplayer is offline   Reply With Quote
Old 01-24-2013, 08:01 PM   #4 (permalink)
I ended up replacing the whole dash unit. It was an easy fix. Total cost was $50 and about 20 minutes.
Old 01-25-2013, 04:27 PM   #5 (permalink)
Hmm where did you get the part? Also, do you think this is a fuse issue?
Old 01-25-2013, 04:33 PM   #6 (permalink)
I bought at Ebay. I checked the fuse but that wasn't the problem. When I took a finer look at it with the flashlight, the gas gauge and odometer had quit working too. Like I said, the replacement was inexpensive and easy to install.
Old 01-25-2013, 04:40 PM   #7 (permalink)
AbCaRed00's Avatar
If it might be only a bulb you may want to see: http://www.insightcentral.net/forums/problems-troubleshooting/21152-climate-control-light-issue.html
