Originally Posted by tybic
My question is what is causing this car to go through so many batterys? If they are going to replace this again I want them to fix it correctly the next time. What do they need to look at?
2002 CVT insight.
My guess is that is nothing to do with the car.
It's probably a combination of the car sitting unused, plus the fact that they put in stock Honda battery cells.
As mentioned earlier, letting the car set unused for weeks at a time is not good for it.
The best thing you can can do is regularly drive it.
Personally I'd skip the stock pack and get one of the upgraded ones from
Adopt a Part or
Bumblebee.
You'll get higher capacity cells (8 amphour instead of 6 amphour) plus you get a 2 year warranty!
And you have the satisfaction of supporting small independent companies.
If you don't want to install it yourself I'd be glad to help up in Madison.
