Inside temperature code - Insight Central: Honda Insight Forum
Old 01-03-2013, 07:11 AM   #1 (permalink)
Default Inside temperature code
My Autostop isn't working. I performed a diagnostic for the climate control and got the following code: 1 alternating with 33. Does this mean that my inside temp sensor is bad?
Douglas is offline   Reply With Quote
Old 01-03-2013, 02:55 PM   #2 (permalink)
without me looking up the codes, check the temp sensor by the front grill-it has a habit of cuting the wires or just falls off, making AS not funtion. A real quick test would be to shut off the climate system, if AS works, check the sensor i mentioned.
ac
295,000miles
biododge1 is online now   Reply With Quote
Old 01-03-2013, 03:21 PM   #3 (permalink)
AS does not work even when I shut off the climate control. It isn't the result of cold outside temp (20 degrees F)- right?
Old 01-03-2013, 05:53 PM   #4 (permalink)
yes the outside temp does effect it. Mine wont auto stop in anything colder than 40°f most of the time.
2001 MT Silverstone. Car # 106
bought 08/19/2012, @ 193k miles and 48.6 LMPG. as of 2/1/13. (49.3) LMPG...
Best trip so far. 104 mpg over 80 miles.
EPS fuse removed,
upper and lower grill block.
rear wiper delete, passenger wiper delete.
Insight for life is online now   Reply With Quote
Old 02-19-2013, 01:56 PM   #5 (permalink)
Sounds like you just initiated the hidden display. You're seeing parameter 1 (inside temp) at 33 degrees C.
http://www.insightcentral.net/forums/116907-post10.html
__
Neil
orac is offline   Reply With Quote
