New owner having problems - Page 2 - Insight Central: Honda Insight Forum
Old 01-23-2013, 07:08 PM   #11 (permalink)
diamondlarry's Avatar
Originally Posted by seeodywhy View Post
Where is the OBD2 port on this car?
On your car, it is on the right side of the center console, on the floor in the passenger side footwell.
Silver '00 MT
90.2 LMPG
Calpod switch
Warm air mod
Grill block
EPS fuse removed
grid charger
OBDII C&C gauge
Old 01-23-2013, 08:02 PM   #12 (permalink)
You check the input shaft bearing by removing the transmission and spinning the input shaft by hand.
It should make a whirring or crunching noise in neutral with the clutch engaged(pedal out).
It's a Honda problem, not necessarily an Insight problem. Your transmission needs to be rebuilt. Sucks.
503-730-8786
info@bumblebeebatteries.com
Old 01-23-2013, 08:05 PM   #13 (permalink)
No biggie. I can rebuild it when it gets a little warmer. Really, on the floor.
seeodywhy is offline   Reply With Quote
Old 01-24-2013, 12:03 AM   #14 (permalink)
That's the spirit!
The transmission overall is easy to remove/replace and work on. There are several threads here detailing it.
The input shaft bearing(ISB) is like a $25 part, but you'll want to replace everything else that needs replacing while you're at it.
503-730-8786
Old 01-24-2013, 12:37 AM   #15 (permalink)
freezin4's Avatar
Default New owner having problems
I am going to the Jessup crazy ray's today to see if I can get those ground straps
Is the stamp for the plugs under the coil packs?
I would get new grounds. They are cheap enough. I've used short tractor or motorcycle ones before. But not worth getting them used. You definitely want them I. Tip top shape. I bought Honda ones for Insight and coated them with liquid plastic. But you should look at the CRZ straps they are better design.
Yes, the A B C or D are visible on the head right next to spark plug holes. (If you are a betting man, bet on B )
Sent from AutoGuide.com Free App
264+K miles
Citrus w/ A/C - #2083
270+K miles
freezin4 is online now   Reply With Quote
