Brake an clutch fluid replacement.
Ride quality can be improved with aftermarket springs.
Honda rear shocks $$$, Monroe's can be adapted cheaply.
Hissing is not too common in my opinion. If the ac is working I might just ignore it.
Ive been searching around this forum with regards to the suspension, seems like trying to find a unicorn. Im not sure if I should do just shocks/struts or change shocks, struts, and springs.
On Majestic I built a suspension list and it seems to be about $1000 with everything assuming I change out the bolts, nuts, the bearing flanges, etc due to surface corrosion from the east coast. Any good source for springs or basically stock from majestic is the way to go?
I'll definately change the clutch fluid too. Is there a big difference between Honda Dot 3 and Dot 3?
The a/c "hissing" sounds kind of like a vaccum line changing suction. It seems to come and go with the ac coming on. everything works but it is very noticable.
The A/C in my Insight has always hissed a bit. It's not a constant hiss, but tends to come and go gradually, probably as the A/C compressor cycles. The A/C has always worked well, so I now consider this to be normal.
Aloha,
Art Isbell
2000 Insight A/C #559
My AC does the same thing, works fine but when the compressor turns off you can hear a hissing sound on passenger side dash. Last year I vacuumed out the entire AC system and properly serviced it with oil and freon, this did help the hissing noise but it has slowly returned over time. I'm leaning towards the expansion valve but deam it not worth replacing at this point since it is putting out cold air and seems to be working fine.
PS:: My wife has doubed my car "The iron lung" because it used to hiss so loudly.
GG:
Try running it without the inside cabin filter, see if that changes the "hissing".
Use: 320,000 mi. @ 57.8 LMPG
Your welcome.
Try using the Google search box on upper left for "Monroe shocks".
The non oem springs are Daewoo Maitz / Chevy Aveo, another site Google. They are stiffer than Honda and most people like them. I'm not speaking from actual experience.
Suspension squeeks can be lower control arm bushings...try lubricating w silicone grease.
Check your lower motor mount, the rubber is probably cracked.
Dot 3 is Dot 3, IMO.
kevin
