I too have experienced the same problem but could never get it resolved completely from the dealer. Probably the best option is to wait it out for a few days.
There are lots of little clips that will crack when the pillar is removed. Here is another place where water can seep back into the cabin. It'll wet the seatbelt and corrode the retractor which may fail and not lock up during a panic brake situation.
My insurance company set me up with a windshield company that didn't head my warning. When they showed the retainer clips shattered from the jerk jerking it apart. They quickly stopped and ordered everything related and some extras.
2000 Insight #5488 AC MT
267000 Miles
Best Tank 875
Best1Way 119.1
I've been reading about "molding", "clips", "strips" & "trim" "a, b, &c pillars" are all confusing me like another language. I've gotten the piece(trim?) off that runs from the top of what I would call the seatbelt pillar(A pillar?) cuz it runs up and down outside where the seatbelt bolt is, and it's clips, from Jeff's write up, but now there is another piece that runs over top the windowuploadfromtaptalk1353422935556.jpg which is what I believe you guys are talking about but I just wanted to confirm this, and that I absolutely have to replace these "clips" under this piece because they necessarily break, right? And why break it with that paint tool? Is pulling it incrementally along it's edge not a good way? Thanks guys
Sent from my SGH-T989 using AutoGuide.Com Free App
I've been reading about "molding", "clips", "strips" & "trim" "a, b, &c pillars" are all confusing me like another language. I've gotten the piece(trim?) off that runs from the top of what I would call the seatbelt pillar(A pillar?) cuz it runs up and down outside where the seatbelt bolt is, and it's clips, from Jeff's write up, but now there is another piece that runs over top the windowAttachment 3931 which is what I believe you guys are talking about but I just wanted to confirm this, and that I absolutely have to replace these "clips" under this piece because they necessarily break, right? And why break it with that paint tool? Is pulling it incrementally along it's edge not a good way? Thanks guys
Choice is kind of simple. Break the clips or break the moulding. I will choose breaking the one-way clips any day. Occasionally the clips are rotten enough you can get away with pulling the molding up, but in many cases you will break the clip mounts in the molding before you break the clips.
Is water leaking in to your car now? If not, I would leave it be. The clips are about $80 for one car's worth. You have to get the (I think it is either seven or eight for each side) most common clips. The most expensive one on each side seems to be ok, and not break (both of mine were ok). The ones at the very bottom of the windshield are also ok, but one of mine was simply missing, so I am glad I bought them. Make sure you use sealer on all the clips when you install them.
Just my 0.02 worth,
Tim Glover
Reason: can't spell
You are correct about the clips being from Honda. Kind of expensive, but I am not familiar with generic clips, and doubt that they would seal water out very well if there were any that would fit.
It becomes a lot clearer how everything works together after you remove a molding. Ask me how I know about breaking the clip mounts on the molding .
I'll always break the clips anytime I have to remove a molding from now on. I have only done my daughter's CVT so far (thank you again to Docrings for all your help), and the person who worked on her car before I got it made it look like a ham-handed butcher did the job. Fortunately they caught on to how to remove the moldings before they damaged too much. Unfortunately, they tried to cobble it back together, so it leaked water.
As far as why I'm removing this part is to get to the rest of the seam that runs to the hatch that I'm re-sealing.
I'm going to try to re-seal one Friday without removing the exterior trim. I think it should work. I'll try to snap a couple pics to prove it can be done
FS: Simple Grid Chargers - 00-06 Insight & 03-05 Civic Hybrid HybridAutomotive.com (Now Includes the Insight/Civic IMA Battery Instructions)
Jeff, I should ask, do you think it's absolutely necessary to go that far into the front of the seam even though my leak is only at the hatch? Common sense tells me I should re-seal it all the way to that hole you discovered, tho I'm not sure I have any holes up there since as I mentioned mine only leaks at the hatch. maybe it's just something I might have to do again in the future, or not in which case $80 on new clips would be a waste. hmm...
