The idea of stacking two or more Honda Insight IMA motors together in tandem fashion has been suggested by others for powering an EV or for enhancing the Insight's battery only performance. The ORNL study on the Accord IMA motor shows what might be expected and a way in which this type of adaptation may be accomplished. We should be able to make up some end plates, adapters, bearings, and shaft for an Insight setup.
An Insight specific conversion/adaptation probably should 1.) bolt up to existing hardware in a tandem arrangement and/or 2.) use Insight parts in a free standing motor for general EV propulsion. A lot of work has been done by Mike and others on the electronic end and hopefully we should be able to work up some practical motor hardware also.
To begin with, on the Insight ICE engine, can someone furnish the dimension between the end of the ICE crankshaft (IMA motor rotor mounting surface) and the machined surface on the ICE block where the IMA motor is mounted? In other words, how far beyond the engine block does the crankshaft protrude (or not). With this dimension we should be able to work out the critical relationship between IMA rotor and stator.
Hugh-Falls
Hugh-Falls
