Auto stop not working? - Insight Central: Honda Insight Forum
Old 08-17-2009, 02:17 AM   #1 (permalink)
mugenRL's Avatar
Default Auto stop not working?
Recently I noticed that Autostop wasn't working on my Insight. My insight has around 600 miles, and it worked before like everytime when I would come to a stop, even stop signs. I'm not sure if this has to do with it, but I added a HID kit a week ago, but autostop still worked then. But now, I hardly even see it using autostop even when I'm on the econ mode. I read in the manual that autostop depends on alot of things, but all the settings are the same as when I bought the car. Not sure what's making it not use autostop.
mugenRL is offline   Reply With Quote
Old 08-17-2009, 06:26 AM   #2 (permalink)
I would try taking out the fuse that powers the HID set and see if it starts auto-stopping again in a day or two - that would let you know for sure if that caused it. I htink it's entirely possible it is the issue.
2010 Insight EX - Tango Red Pearl
Former Cars:
2007 Honda Pilot EX 2WD
2005 Infiniti G35 Coupe
2003 Infiniti G35 Sedan
1999 Nissan Altima GXE
1989 Dodge Daytona (got as hand-me-down in 1998 )
CobaltDragon is offline   Reply With Quote
Old 08-17-2009, 01:48 PM   #3 (permalink)
From another "auto-stop" related post:
(Autostop is the car shutting itself off when your at a stop)
Autostop only works in D (not R or S/L)
Autostop will not work if you have the Climate Control set to Defrost or Defrost/Feet
Autostop will not work if the AC is on but ECON is off (If ECON is on it should Autostop w/ the AC on)
Those are the basic ways to cause auto-stop not to function. Definitely see the dealer if you are experiencing otherwise.
euro sport is offline   Reply With Quote
Old 08-17-2009, 05:22 PM   #4 (permalink)
mugenRL's Avatar
Hm, I have to check if my climate control is set to feet.
