Shuddering with rear window down - Insight Central: Honda Insight Forum
Old 10-17-2009, 10:20 PM   #1 (permalink)
Send a message via AIM to WoodyInsight
Default Shuddering with rear window down
Has anyone else found this problem. I was merging onto the highway this morning. I had decided to take my lab with me therefore I had the rear window down as he likes to stick his head out and sniff. As I approached 55 or so the whole car started to vibrate ( I'll call it an earthquake). I mean the seats were shaking and the rear view mirror looked like it would shake off the windshield. There was also a loud thump thump thump noise that was almost deafening. I immediately thought I had a flat but I decided to roll the window up since this was the only change to my normal driving habits and the noise stopped instantly. This "earthquake" was repeated with both rear windows down but only down 1 at a time. I have never experienced anything like this with any other car I have owned? This makes the car impossible to drive with the rear windows down and the front ones up.
WoodyInsight is offline   Reply With Quote
Old 10-17-2009, 11:48 PM   #2 (permalink)
Fl_Fyr_Fytr's Avatar
Funny, same thing happens to me but instead of the windows, it's when I turn the dial in the middle of the dash. Could swear it was an earthquake
Seriously, is the I2 really that bad?
Thundersyt
Fl_Fyr_Fytr is offline   Reply With Quote
Old 10-18-2009, 12:12 AM   #3 (permalink)
Default Comedian
This is the only negative that I have found with this car after 3000 miles other than I feel it needs a bigger gas tank.
Old 10-18-2009, 04:25 AM   #4 (permalink)
My 2003 Jaquar does the exact same thing as you described -
That Thumping noise is deafening !
Bummer, if my new Insight does the same thing
I will find out tomorrow
Must be some aero thing happening -
You would think that the Designers would have caught the problem
TNQR-TOY is offline   Reply With Quote
Old 10-18-2009, 03:23 PM   #5 (permalink)
It may be that the I2 is more extreme because it is a light car, but every other car I have owned does exactly the same thing. If I don't at least crack a front window open when a rear window is open, the pounding is deafening.
2010 EXN, White/grey
2004 Accord 4 cyl (sold to my son)
2005 V70 (wife's car)
2001 Forester (daughter's car)
Eastern MA
waterdog is offline   Reply With Quote
Old 10-18-2009, 04:51 PM   #6 (permalink)
I believe this is called Helmholtz Resonance. I notice that it happens on the I2 at speeds greater than 50mph.
I have experienced this in other rentals cars that I have driven for work.
corey415 is offline   Reply With Quote
Old 10-18-2009, 06:57 PM   #7 (permalink)
im pretty sure this happens to any 4 door car...
crxgator is offline   Reply With Quote
Old 10-18-2009, 08:56 PM   #8 (permalink)
This happens on any 4 door car. Just put down the front opposite window too; it should fix the problem. This is not a design problem, the more aerodynamic your car is the more likely this problem will occur, it's creating a low pressure system inside the cabin.
Urban legends when I was growing up around this effect:
1) It can create a frequency low enough to crack glass, never experience nor tried to replicate it.
2) It can knock you out if exposed to it long enough.
nameless00 is offline   Reply With Quote
Old 10-19-2009, 11:53 AM   #9 (permalink)
Every 4-door car I'd ever owned did this. I always referred to it as the "Helicopter Effect". As already mentioned, just crack your front windows a bit and the noise will go away.
euro sport is offline   Reply With Quote
Old 10-21-2009, 12:06 PM   #10 (permalink)
Cool
Thanks, I guess I should have known this but this is the first 4 door car I have owned.
