Originally Posted by numbness4sound
Haha, it's really hard to describe, but if you were experiencing it, you would know.
Maybe the electric motor is causing a bit more vibration because it's cold? Or maybe the louder noise could be causing it? I'm not hearing any difference in noise though.
I drove my car around having parked outside for a number of days, and things do seem more stiff, but they loosen up after a bit fo driving but the shocks seem pretty stiff still, I can see how that combined with higher PSI on the tires could lead to a lot more transmission of road vibrations to the car..
If you think it's an alignment problem you can try a test, drive the car with no hands on the stirring wheel straight for about 30 yards at some reasonable and safe speed parallel to the side walk, if it pulls to one side slightly or another then you have alignment problems.
If there is a lot of wobble from one side of the car check to see if the lead weights are still on your tires and if the alloys are still in good shape.
Otherwise I'm out of ideas, if you find out do let us know.. Good luck..
