-3 degrees camber?
Got an alignment and balance/rotate a few weeks ago from all the potholes the last few months.
I decided to use the shop down the road vs the Dealer. They were 30 bucks cheaper and let me watch.
The computer did not list a 2010 honda insight or 09 fit. They used an 09 accord. Thats ok, I had an alignment done 2 weeks after I lowered my insight at the dealer and the spec sheet said 07 insight.
I got out the owners manual and showed them the page. The computer said my toe was in .05 and the wheels were both -3 for camber on inwards. THe computer said for that car it was in spec and not to worry.
I wanted to zero that out, but they said dont bother. Ive looked online, but cant find camber bolts for this car. A buddy said to use a power tool and longate the hole for the top mount.
The shop zeroed out the toe and the wheels n tires were still balanced.
I see a bolt for an 09 fit on ebay that does 1 degree either way.
Should I worry? It seems my car has sagged an inch since installing the springs.
