Question on Oil Change (Drain Plug) - Insight Central: Honda Insight Forum
Old 04-17-2010, 08:00 PM   #1 (permalink)
Default Question on Oil Change (Drain Plug)
Hello everyone,
Today I tried to get underneath my Insight II to perform the first oil change. I got everything ready(removed the panel) except the drain plug. it's not a regular hexagon type of bolt. it's some kind of square-type bolt. I went to Checker but still couldn't find the right tool
so just wondering if anyone has seen it before? what kind of wrench should I use?
Thanks in advance,
wilsonckl is offline   Reply With Quote
Old 04-18-2010, 12:52 AM   #2 (permalink)
I changed my oil last December and I don't recall the oil drain plug being an unusual size/shape. Are you sure you aren't looking at the drain plug for the CVT fluid?
corey415 is offline   Reply With Quote
Old 04-18-2010, 02:07 AM   #3 (permalink)
I should have taken a picture for that. I followed the manual to remove the panel
I was hoping to see bolt like the following,
Instead, the drain plug has a square hole, which is more likely to be driven by a socket wrench,
I tried a couple of socket wrench, but they won't fit.
Thanks for the help,
Old 04-18-2010, 12:10 PM   #4 (permalink)
I use a regular socket on my wrench, I believe it's either 8 or 10 mm? I changed my I2 awhile ago and the CVT fluid uses a square head, 3/8" if I recall. The oil drain plug is a regular socket, look at a Honda parts website to get the exact size. Have a breaker bar or extension, as well as an oil filter removal tool (I got one at WM for ~$5 if I recall) ready as they can be a pain to get off the first time.
Old 04-18-2010, 01:42 PM   #5 (permalink)
Premium Member
satchel's Avatar
Are you sure it isn't a 14mm hexagonal head?
http://www.hondaautomotiveparts.com/...LOCK+-+OIL+PAN
Old 04-18-2010, 03:48 PM   #6 (permalink)
Honda Automotive Parts
That's probably right. I just leave it out in the top of the tool box since it's about the only size I use on a regular basis. I don't really pay attention to what size it actually is anymore.
Old 04-18-2010, 04:37 PM   #7 (permalink)
The transmission drain plug is on the drivers side under hte little piece with 4 screws in it. Its a 3/8 rachett head. You should change that every 15 thousand.
The engine is on the passenger side and faces rearward and is either 14 or 17mm, I cant remember which. To get to it you need to undo like 4-6 of those plastic push pins and remove about 8 screws and lower the center most of the belly pan.
Old 04-18-2010, 09:47 PM   #8 (permalink)
Thanks a lot everyone, will try it out
