lugging on hills - Insight Central: Honda Insight Forum
Old 09-07-2010, 01:19 AM   #1 (permalink)
Default lugging on hills
in our area there are some small but steep hills, when i hit one the i2 lugs and i have to manually downshift into s and hand shify
is this normal?
patb is offline   Reply With Quote
Old 09-18-2010, 09:12 PM   #2 (permalink)
Its normal in econ mode. The car goes into a fake atkins cycle in econ mode and loads the engine to 85% before it "upshifts". The atkins cycle leaves the intake valves open part of the compression cycle, so it feels like you got a vacuum leak, but its a mode efficient mode by reducing pumping losses
Old 11-06-2010, 11:17 AM   #3 (permalink)
Default Should steeper hills be taken with ECON off?
Or, what is the best way to manage hills while still working for good MPG?
(Newbie here -- first week!)
catsight is offline   Reply With Quote
Old 11-18-2010, 01:03 AM   #4 (permalink)
Best is when you approach the bottom you go the fastest you legally and safely can. Then let the car loose speed as you climb again, to the slowest safetest legally speed you can as you approach the top.
Welcome aboard.
