ceiling lights/ dome lights/ interior lights not working with new bulbs - Insight Central: Honda Insight Forum
Old 12-16-2010, 01:09 AM   #1 (permalink)
Default ceiling lights/ dome lights/ interior lights not working with new bulbs
fuse problem? which fuse is it? i dont see it on the user manual
Anadivine is offline   Reply With Quote
Old 12-16-2010, 02:54 AM   #2 (permalink)
Those lights are limited by Fuse #1 15amp. There are some other systems on that fuse too.
Have you been trying to change to LEDs or working on the lights or something? If the fuse is blown, it's pretty important to know why and correct that problem.
Old 12-16-2010, 09:30 AM   #3 (permalink)
Some leds you need to turn around as they only work when inserted a certain way. Sometimes those cheap chineese leds you get from ebay are just junk. Id try a regular bulb again and see if it still works, if so you got some bad leds.
Myself I shorted out a slot for a bulb and ended up having to get a new switch, the fuse didnt blow.
Old 12-17-2010, 10:42 PM   #4 (permalink)
the fuse is fine. i did not change anything. using stock. could it be the switch instead?
Old 12-17-2010, 11:30 PM   #5 (permalink)
Each lamp has its own switch. What if you switch back ti the regular bulbs?
Old 12-18-2010, 11:05 PM   #6 (permalink)
hmm i was did not change anything. i'll bring it down to the workshop tmr then i guess.
