Now My JVC KW-AV726 2Din Headunit is down! - Insight Central: Honda Insight Forum
Old 12-17-2010, 02:50 PM   #1 (permalink)
Default Now My JVC KW-AV726 2Din Headunit is down!
Please help! My headunit screen is blank! only the ATT button is working! However the music only plays like 5-10sec and it will shut off by itself! what is going on! I have been using this headunit for almost 1yr+
Anadivine is offline   Reply With Quote
Old 12-17-2010, 11:55 PM   #2 (permalink)
Is this with the car running or key in accessory? What about key turned to on, but no engine running?
Off hand Ive seen head units cut off like that when the voltage regulartor for the alternator go bad and the electrical system is pushing 16 volts or more.
Old 12-18-2010, 11:06 PM   #3 (permalink)
its with both key turned to on and engine running. i suspect its a bad fuse behind the headunit.
Old 12-19-2010, 07:44 AM   #4 (permalink)
Do you think it's a fuse if the music plays about 10 seconds then shuts off?
Old 12-19-2010, 07:56 AM   #5 (permalink)
No iDea.. What do u think? Spoilt unit?
Old 12-19-2010, 06:38 PM   #6 (permalink)
A fuse is designed to allow current flow until it's limit is exceeded, and then it blows, cutting off current forever. It can never flow again.
If you have a unit that will play for 10 seconds and stop, then next time it plays for another 10 seconds and stop, that goes against the design of a fuse.
It sounds like something is overheating. Heat is a resistance and when the resistance is too high, there is no current flow. When the unit shuts down and cools off, the resistance tapers off allowing current flow again.
First make sure your power and grounds are solid. Make sure the unit is properly ventilated. Make sure your speaker ratings and hook up are correct and solid.
It sounds more like a power circuit than an amp circuit. I'd try another power source just to make sure.
Old 12-19-2010, 10:23 PM   #7 (permalink)
Id try an audio forum or calling jvc. A search online did not turn up much.
