new battery... advise please! - Insight Central: Honda Insight Forum
Old 01-10-2011, 03:48 PM   #1 (permalink)
Default new battery... advise please!
so after people here mentioning upgrading the 12v battery has helped i wanted to do that too
i went to autozone and asked for advise
i got a group 51 battery just like cobb and i wanna install it already but idk if i got the right one
heres a pic
the guy got me scared saying there not liable if something happens to the car
please help!
Old 01-10-2011, 07:20 PM   #2 (permalink)
That looks righ to me Cheesie. Group 51 is just a specification standard for size. Group 51 is the size you need.
The R means that the + and - are reversed from the standard battery. The picture you show has the + terminal correct for our cars.
The DLG dash number probably means Dura Last Gold.
The sellers are never liable for things you modify.
I think that you are good to install it. Let us know how it goes.
Old 01-10-2011, 09:25 PM   #3 (permalink)
k thanx
is that a good amount of amps i got?? 500 or 625??
idk anythin bout batteries but im pretty confident i can install it myself
ill just undo the negative thing first then the positive ( red one right?) the take out the plastic holder too and when putting the new battery on ill just connect the red one ( +) first and then the negative
but i dont get it cobb or someone else said that the car starts with the new battery ( not with the hybrid battery anymore)
does that really matter?
Old 01-10-2011, 10:14 PM   #4 (permalink)
The start with the car battery and engine starter was a one time deal as I recall.
Don't worry about cranking amps.
The only other think I can add is if you have a stock radio, make sure you get your radio code BEFORE you disconnect the battery. Someone may have written in your manual somewhere. Otherwise your dealer can get it for you. I think you might can get it from the Honda owners link.
I'm not sure what all you will lose when you remove the battery. You might lose some MID data such as trip counter, avg mpg, or something like that. Or maybe not. Just be willing to accept if some of that stuff resets.
Old 01-10-2011, 10:29 PM   #5 (permalink)
yeah ive got my battery disconnected before
i can live with the reset data and i got the code too
i paid 120 for this battery!!!!
i think i overpaid... it better be better than the regular duralast brand
right now i have 39.5 mpg and going down for some reason, ive bin drivin the same i even stoped driving S mode for a while but hasnt worked...
one last question..
when i switch to the new battery should i do the reg thing where i stay on P and set up the handbrake so i can charged both batteries to have a good start??
or maybe i should drive it first before doin that?
Old 01-10-2011, 11:12 PM   #6 (permalink)
The regen is a matter of opinion. My suggestion would be to do the regen just BEFORE you swap out the battery. That will make sure that the IMA battery is charged. After that, swap out the 12 volt battery, then take it for a drive (about 15 minutes) and see how it behaves. It should behave normally or better than normal.
I wouldn't worry about the cost. First of all, you've already paid. That's behind you. Second, a new battery should help in the long run. If you overpaid by $40, that's just a couple of dollars a month in the long run. If you really worry about that stuff, you need to do your homework before you go out to buy.
Old 01-10-2011, 11:19 PM   #7 (permalink)
Wow, thats some specs. My battery is like 70 amp reserve and 435 cold cranking. I paid a little over 69 bucks.
My car started only once with the 12 volt starter. Never heard it before and I had disconnected the battery to reset the computer. It starts normal since then.
When you restart the car it will do a regen anyway, Id save the gas.
If you are really anal, you would hook the battery to a charger over night to top it off. They are typically 80% charged from the factory. Make sure you get a new looking clean battery. If its dusty and dirty, Id exchange it.
Old 01-10-2011, 11:46 PM   #8 (permalink)
well i was kinda lazy to go keep looking for a battery
k then my plan for tm is charge the car before swaping batteries, then im going to do some things i gotta do ( im not gonna charge the battery ) hopefully ill get some good results
well the battery looks pretty new to me no sign of old at all
still has the black cap on the negative thing
Old 01-11-2011, 09:55 PM   #9 (permalink)
well the swapping was fair for my first time
i felt like i get more power there way more asst and i only got one reg
i drove on hills where the battery usually drains ( even if its ful) and the car did good this time
i still need to drive it around more
so far im ok with this new batt
Old 01-11-2011, 10:57 PM   #10 (permalink)
BlueIMA's Avatar
Cheesie how many miles your I2 has? I'm in the 27,000 range and starting to get the force regens a lot more frequently like some have been reporting. I am also thinking about upgrading my 12V battery as it appears to help with force regens and economy as well.
________________________
2010 EX/Navi Clear Sky Blue
20% tint all around
Weathertech Floorliners
OEM Mud Flaps
17X7 MSW Wheels
205/45/17 Yokohama Avid Envigor Tires
Eibach Pro-Kit Lowering Springs
Alpine M-300 4 channel amp
Sound Ordnance 8" Amp/Sub
DDM 35W HID 6000K for low beams
Blacked out taillights and mirror markers
Direct Wired Escort 8500 X50 Radar
Shark Fin Roof Antenna
K&N drop in air filter
Insight badge removed
LED reading, dome and license plate lights
BlueIMA is offline   Reply With Quote
