Longer XM Radio antenna cable ..?? - Insight Central: Honda Insight Forum
Old 02-15-2011, 10:30 PM   #1 (permalink)
Default Longer XM Radio antenna cable ..??
2010 Insight EX
Had XM installed, and it's antenna is on the front windshield .
Does anyone make an antena with a longer cable so it could be attached to the REAR window? It would have to be compatible with the 2010 Insight unit
Thanks ...
wjpm is offline   Reply With Quote
Old 02-16-2011, 10:35 AM   #2 (permalink)
You could buy an aftermarket antenna and hook it up either on the window or roof. I use to have a sony xm radio and it had a shark fin antenna with 50ft of cord.
Old 02-16-2011, 05:35 PM   #3 (permalink)
Can anyone recommend a specific antenna that fits on the inside glass with a long enough cable to go from the head unit to the back glass? That will fit on the factory navi unit?
Old 02-21-2011, 10:34 PM   #4 (permalink)
Id try XMFanStore.com - Authorized XM Satellite Radio Dealer - Toll-Free: 877-4-XMRADIO Sometimes its trial and error. I believe the antenna connector is fairly universal now. Even when they first came out it was 2 wires one for sat and one for ter. Id visit and or call that website.
