What Warranty work have you had done? - Insight Central: Honda Insight Forum
Old 02-24-2011, 03:03 PM   #1 (permalink)
Default What Warranty work have you had done?
OK, maybe I'm not seeing the "warranty work sticky" but I'm wondering what warranty work you've had done? Also have you tried to have anything fixed under warranty that was rejected? Was the work covered under a Technical Service Bulletin?
(TSB list @ http://www.alldatadiy.com/TSB/24/102450b4.html)
(Complaint search @ http://www-odi.nhtsa.dot.gov/complaints/)
steve_b1 is offline   Reply With Quote
Old 02-25-2011, 09:15 AM   #2 (permalink)
I had the infamous little roof trim piece replaced under warranty, no questions asked.
Old 02-25-2011, 12:25 PM   #3 (permalink)
Thumbs up
+1 - 50K miles and that's the only issue!
jonniedee is offline   Reply With Quote
Old 02-25-2011, 12:52 PM   #4 (permalink)
Trim piece aka rubber roof strip. +2
Old 02-25-2011, 10:41 PM   #5 (permalink)
I had a score develop in one of my brake rotors. I had less than 2,000 miles on the car. I was given a free loaner and the rotor was turned under warranty.
However, I also had the rubber roof strip come loose but took care of it myself using black silicone.
Old 03-05-2011, 12:32 AM   #6 (permalink)
I'm just over 2000 miles on my 2010 EX and, I don't know, probably the third day I had it the rubber roof trim popped out.
The dealer said they'd never seen such an issue. I suggested the maintenance tech take my car through a touch-less car wash as part of a continuous learning program so they'd be more familiar with it, but they weren't interested in giving me a free car wash.
They did replace the rubber trim kit with another set identical to the originals, though, so while I appreciate that they honored the warranty, I suspect they'll be seeing me again.
-P
2010 Insight EX -- Alabaster Silver Metallic
Chasing MPGs since Feb. 12, 2011
popennell is offline   Reply With Quote
Old 04-19-2011, 05:12 PM   #7 (permalink)
I never run my car through a car wash so no problem with the rubber strip. Did have an issue with the moulding around the front window and they fixed it with no problems. The other 2 warranty issues I had was one of the rear shocks failed and they replaced both and needed to have a new cruise control switch put in.
Brian1 is offline   Reply With Quote
Old 04-19-2011, 11:18 PM   #8 (permalink)
zurk's Avatar
plastic trim on rear right passenger side.
zurk is offline   Reply With Quote
Old 04-23-2011, 02:24 AM   #9 (permalink)
We had a sticky/broken detent in the left hand paddle shifter 30k. We complained about a sticky shifter interlock also but nothing was done with that. I had that apart a couple weekends ago and honestly could not see anything wrong with it, I was trying to fix another problem that has since disappeared with the horn.
Chris
2010 I2 "the silver slope"
2005 Element
lots of cast iron in the basement.
in2steam is offline   Reply With Quote
Old 05-04-2011, 08:35 PM   #10 (permalink)
Mine came off just last week from the intense wind and rain we had in Syracuse. Got it taken care of Tuesday - just glued it back with silicone. I doubt they did the other one, which seems kind of lazy. Just because it hasn't come up now doesn't mean the design isn't flawed and it won't someday.
Dibidoolandas is offline   Reply With Quote
