Moisture in Tail Lights? - Insight Central: Honda Insight Forum
Old 03-30-2011, 06:43 PM   #1 (permalink)
Default Moisture in Tail Lights?
I noticed some moisture inside my 2010 driver-side tail light recently. Looks like there's a TSB regarding this. Has anyone else experienced this and does anyone know what the TSB says?
caedward is offline   Reply With Quote
Old 03-30-2011, 10:26 PM   #2 (permalink)
Looks like the warranty covers it. Here ya go:
July 9, 2010
Applies To:
2010 Insight-From VIN JHMZE2H..A5000001 thru JHMZE2H..A5029575
Moisture in the Taillight
SYMPTOM
Condensation forms inside the taillight lens. The condition seems to happen most when the vehicle is driven from a high-humidity environment to one with low humidity. Water may also collect inside the taillight if water is sprayed directly at the taillight.
PROBABLE CAUSE
The taillight air vents are too restrictive, and one of the wiring grommets within it may not be properly sealing.
CORRECTIVE ACTION
Install less restrictive taillight vents, and seal the wiring grommet.
PARTS INFORMATION
Drain Tube KitP/N 06335-TM8-305
REQUIRED MATERIALS
NOTE : Either material is acceptable and only one is required.
3M Strip Caulk, black3M P/N 051135-08578
3M Window-Weld round ribbon sealer
5/16 in. X 15 ft.3M P/N 08611
TOOL INFORMATION
KTC Trim Tool SetT/N SQJATP2014
WARRANTY CLAIM INFORMATION
The normal warranty applies.
Failed Part: P/N 33501-TM8-A01
Defect Code: 07407
Symptom Code: 05911
Skill Level: Repair Technician
Old 03-30-2011, 11:53 PM   #3 (permalink)
Thanks, I got this problem too.
