Engine codes - Insight Central: Honda Insight Forum
Old 03-30-2011, 08:04 PM   #1 (permalink)
Default Engine codes
Just took my fathers OBDII scanner and pluged it to my Insight and I got two codes first P0004 which is Fuel Volume Regulator Control Circuit High, and the second one was a C183A code that one I could not find any info on. Any one had any issues with this. I got 47K miles on my Insight and I am hoping I won't have any issues with my Insight 'cause I am regretting buying it (should have bought VW with diesel engine).
The thing that I love most about my Insight, is that it's not a Prius.
K0mbi is offline   Reply With Quote
Old 03-30-2011, 09:52 PM   #2 (permalink)
Zwolfe's Avatar
Engine light on?
Old 03-30-2011, 10:21 PM   #3 (permalink)
go to www.hondatechinfo.com buy a 3 day subscription for $10 and look up the codes and troubleshooting procedures. TDI's are nice. I had one for several years B4 the Insight.
Old 03-30-2011, 11:54 PM   #4 (permalink)
This is the 2010 Insight? Did you get an error light or just wanted to see what happens when I plug this in?
Id clear the codes and see if they come back. I had the generic chassie error in my car. I cleared it and havent seen it since. I think its like c655565 or something close.
Old 03-31-2011, 04:37 PM   #5 (permalink)
Yeah, 2010 Insight, and that's what happened had the scanner and plugged it in to see if it comes up with any codes and it did, I will clear the codes and see what happens in a few.
