custom settings help - 2010 EX - Insight Central: Honda Insight Forum
Old 04-06-2011, 12:19 AM   #1 (permalink)
Default custom settings help - 2010 EX
I'm trying to custom-set my door locks and not having success... I can bring up the the change menu by holding down the "i/arrow" button for a few seconds just like the manual says & I can scroll through the 3 screens of info using the i/arrow button but I can't get out of that initial menu (pressing the sel button has no effect). What am I missing here? TIA
steve_b1 is offline   Reply With Quote
Old 04-06-2011, 12:43 AM   #2 (permalink)
Its a pain for me too, thought I was too old for all this high tech stuff?
Anyway once I enter that mode you basically got like 3 options, exit, change and save if I recall correctly. You move to change, then scroll through to door locks. Its like you need to hit select twice for it to acknowledge change.
I have mines setup so the dome stays on for max time. No auto locking with shifter or drivers door. It will auto lock if I do not open a door once unlocking it once and 2 unlocks unlocks every door.
Old 04-06-2011, 12:46 AM   #3 (permalink)
Thanks! I'll give it a shot again. Edit - Bingo! All set.
