2010 Insight Sticky Hatchback - Insight Central: Honda Insight Forum
Old 04-30-2011, 03:11 PM   #1 (permalink)
Default 2010 Insight Sticky Hatchback
I'm not sure, why, but sometimes, the hatchback won't open.
it's not the locks, i can hear them unlatching and it's not the release,
i trip that and hear it retract but the hatch won't open....
Anyone got a suggestion?
patb is offline   Reply With Quote
Old 04-30-2011, 03:23 PM   #2 (permalink)
jcbesq's Avatar
sometimes you have to hit the auto door lock release on the key fob an extra time
JB
2011 Insight LX - Black/Black
Old 04-30-2011, 08:32 PM   #3 (permalink)
tried it, no luck.
Old 05-01-2011, 12:24 AM   #4 (permalink)
What is the condition of the rubber seals all around the hatchback?
I would try some silicon lube and see...
Old 05-01-2011, 01:57 AM   #5 (permalink)
jcbesq's Avatar
i was thinking a mechanical problem too - also check for binding in the hinge mechanism and maybe put a little lithium grease around the latch if it's not functioning properly
JB
Old 05-01-2011, 10:41 PM   #6 (permalink)
Its the gasket. Need to lube it or give it a had tug the first opening once its been shut for a week.
Old 06-16-2011, 11:38 PM   #7 (permalink)
what do i lube it with?
Old 06-20-2011, 10:11 AM   #8 (permalink)
Use spray silicone. its also good for cvc boots too.
I spray some on a rag, then wipe the gaskets of all my doors.
