Sounds like a compression test is in order if not a radiator pressure test. If the smell is outside the car that rules out the heater core. My radiator from my accident was leaking at the bottom center from the fan assembly.
I believe the cooling system holds 3qts and the outside overflow tank makes it 4.
I believe any auto store has the pressure tested. You want to attach this where the radiator cap goes, pump it up to a few psi or so and start looking. Id check the bottom of the radiator and the bottom of the water pump for wetness.
