TPMS question - Insight Central: Honda Insight Forum
Old 12-07-2011, 05:24 PM   #1 (permalink)
Default TPMS question
I had a flat tire. TPMS warning light came on.
I took the car to Discount Tire and they ended up replacing all 4 tires (too worn out to fix). As part of new tires, they also replaced the valves. They reused the TPMS sensors and mounted on new valve housings.
I drive the car off and the TPMS warning light is still on.
I went back to Discount Tire and they scan the tires with a hand held device. They found one tire not reading. They replaced that TPMS sensor.
According to them, all 4 tires are reading now, but my TPMS warming light doesn't go off.
They said only the Honda dealer can reset the light. Is that true?
The dealer wants to charge me 0.5 hours to diagnose.
So are we supposed to pay dealer fees every time we get a flat?
MPBK is offline   Reply With Quote
Old 12-07-2011, 05:37 PM   #2 (permalink)
There is a procedure to reset them I believe you inflate to 40 psi, then return to normal. The procedure should be online and generic to any Honda.
Old 12-07-2011, 05:57 PM   #3 (permalink)
That sounds easy enough, but... what's the rest of the procedure?
Can you post your link? I can't find anything supporting what you said.
What I found says that I will need to pay the dealer.
How to put in "learning mode" to reset the TPMS sensors - Honda Odyssey Forum : Odyssey Minivan Forums
Old 12-07-2011, 07:18 PM   #4 (permalink)
What I read after searching the web it said just inflate tires to normal pressure and it should reset. Check your spare tire to make sure it is properly inflated.
I'm am not sure but I've been told that some spare tires have the pressure sensor in them also, it could have been the spare tire that started this entire event in the first place? Let us know what you find out.
Old 12-07-2011, 07:48 PM   #5 (permalink)
I have had the TPMS go off due to low pressure. When the tire was reinflated it went off in a minute or so with no other intervention. The manual says it does not monitor the spare and the TPMS warning will go on if you mount the spare after a flat,so the problem is not the spare. It also distinquishes between a "Check TPMS System" warning that will go on when it is not receiving a signal and the "Low Pressure Warning" (looks like a cross section of a tire) that happens when it is getting a reading but it is low. I suspect the tire installers have damaged one of the sensors.
2010 EX Sky Blue since 11/2/09
insightfulone is offline   Reply With Quote
Old 12-07-2011, 08:04 PM   #6 (permalink)
You do need to have the TPMS synced to the computer. However you do not have to go to Honda to have it done. Better tire shops have the machine to do it.
Old 12-07-2011, 08:08 PM   #7 (permalink)
Me too. It's fairly easy to do and happens all of the time. The whole tire pressure system SUCKS!
Old 12-07-2011, 10:14 PM   #8 (permalink)
Please read my post #1. I described the scenario in detail. Yes. I have both lights on.
Don't know if Discount Tire damaged one of the original sensors, but they replaced the sensor that wasn't responding to their hand held device.
If you read the link in my second post, eventually you'll come to a post by someone who apparently works as a Honda technician. He seems to know what he's talking about and says that once a new sensor is installed, the computer needs to be programmed to recognize the new sensor ID.
That makes sense, since if the computer were to just pickup any sensor signal in the vicinity, it would pick up the signals from a car next to you in a stop and go traffic situation, throwing off the TPMS.
So, net net, we need to pay Honda each and every time we service the tires at a non-dealer facility?
One of my pet peeves is the amount of gimmicky gadgets manufacturers have inserted in cars over the years, all in the name of safety. But this TPMS thing is just pathetic. One thing is to force us to drive in day time with headlight on, another is to force me to service my tires at the stealership, paying them inflated fees.
I can monitor my own tire pressures, thank you very much!
Old 12-07-2011, 10:26 PM   #9 (permalink)
NO. The better equipped garages and tire shops have the device to sync the TPMS to the computer in your Insight. The device is like 2-3 grand. It only becomes an issue when the tire guy breaks one of your TPMS or when it dies after 5-6 years.
Old 12-08-2011, 12:37 AM   #10 (permalink)
Found this, it is pretty informative:
Honda TPMS Sensor Replacement
