CHK Emmisions and CHK VSA Light
I brought my car in for an oil change at Valveoline. During the change the Check Emissions warning came on the user display. A short while later, also during the oil change, the Check VSA light came on.
I have shut off the car and started it back on a few times. Drove the car home about 5 miles, turned it off and on again. Its not looking like it is going to fix itself.
During the oil change I had the key clicked to the run position, but not started. I had Oil and both filters changed out. The Emission warning happened while the tech was under the hood. The VSA cam on when I re-started the car and the end to check oil pressure.
Where should I start?
2010 Insight, 43,600 miles
Put new tires on about 4 months ago (light has never come on prior to this). Not same size, but approved by honda according to discount tires (slightly bigger tire in order to get a better quality tire).
Moved to correct forum
Moderator Eli
