Squealing at high speed? - Insight Central: Honda Insight Forum
Old 01-13-2012, 09:38 AM   #1 (permalink)
Default Squealing at high speed?
I have noticed this strange behavior that only occurs at highway speeds, 70mph+. I hear this weird squealing noise coming from the front end, it sounds almost like a turkey or a turkey call box. It *seems* like it happens when there is a strong wind draft. It's concerning me a little bit because I am taking a trip up to NY in the spring in the Insight. Has anybody had this problem before?
2011 Insight
2003 WRX
Steg is offline   Reply With Quote
Old 01-13-2012, 11:27 AM   #2 (permalink)
The big clue that I'm catching in your thread is "it happens when there is a strong wind draft". I'm guessing this is related to a panel being loose somewhere under the car or around a wheel well, as the air passing over the panel increases it is causing the loose panel to osolate (vibrate) thus causing your turkey call box sound.
Had a buddy with a Honda Accord that had a strange noise that only occured when he drove in a westerly direction. Rode with him for a few miles and after several turns and being baffeled had him retract his antenna back into the windshield post and the sound completely went away. (was an 80's Accord)
Not saying it is wind related for certain but that is my guess based on experiance. Jack up the car and look for missing panel fasteners or panels that could possibly vibrate in the wind.
Old 01-13-2012, 11:53 AM   #3 (permalink)
After my accident my car started to sound like a harmonica at highway speeds. Turned out the belly pan wasn't installed correctly.
Old 01-13-2012, 10:49 PM   #4 (permalink)
How did they screw that up?
Old 01-14-2012, 09:37 AM   #5 (permalink)
I guess they held it in place and used a screw gun complete with wood screws to put it where they want it.
Old 01-14-2012, 09:39 AM   #6 (permalink)
Zwolfe's Avatar
I'm placing my bet on a underbelly pan not completely in place / installed incorrectly.
Old 01-14-2012, 11:07 AM   #7 (permalink)
From what you've told us, it sounds like the guys at the body shop that did your repairs are a bunch of goobers.
Old 01-14-2012, 01:34 PM   #8 (permalink)
Well, one of the body shops that called me and later turned the job down swore to me the car had aluminum body panels and how expensive they were to fix and weld. I told him the pervious shop was going to replace and paint.
Old 01-14-2012, 03:25 PM   #9 (permalink)
Like I said, goobers. I had a bunch of those repair my truck years ago and tried to get way with(actually did) shim the bent frame with big washers. After multiple complaints I got a junkyard frame.
Old 01-14-2012, 05:41 PM   #10 (permalink)
Close enough for government work?
