2013 Insight EX Paddle Shifter Problem - Insight Central: Honda Insight Forum
Old 01-28-2013, 09:12 PM   #1 (permalink)
Default 2013 Insight EX Paddle Shifter Problem
On my new 2013 Insight EX when I use the paddle shifters in "D" mode after about a minute, the paddle shifters will turn off and go back to automatic. I have tried several times and it never stays in manual for more than a minute, it will stay in manual without issue in "S" mode.
Also when in "S" mode I can stay in automatic until I pull the paddle shifter and than it will change to manual, but when I pull and hold the shifter to switch back to automatic, it does not work, it stays in manual until I switch the car back into "D" mode.
I have read the owners manual several times, and the modes are not working as they should when following the directions. Has anyone else had these issues?
2013 Honda Insight EX
W4LNY is offline   Reply With Quote
Old 01-28-2013, 09:55 PM   #2 (permalink)
They are functioning correctly per your post.
Sent from AutoGuide.com App
Old 01-28-2013, 11:33 PM   #3 (permalink)
[QUOTE=Cobb;254184]They are functioning correctly per your post.
How do you figure? I cannot use the paddle shifters in "d" mode at all, since it shits them off right after being turned on, and in the manual it states you can use the paddle shifter in "d"mode and have access to 5 virtual gears?
Old 01-29-2013, 04:51 AM   #4 (permalink)
Default Re: 2013 Insight EX Paddle Shifter Problem
D mode is semi automatic. In my experience our will only hold the gear ratios if you are decelerating, cornering or going downhill.
From what you've described, it sounds like yours are working perfectly. If you want it to maintain your selected 'gear' you'll have to drive in S.
Sent from my MB526 using AutoGuide.Com Free App
Uriel is online now   Reply With Quote
Old 01-29-2013, 08:59 AM   #5 (permalink)
jc2bg's Avatar
That's my understanding as well, based on my reading of the 2013 manual and the explanation of my dealer.
2013 Insight EX (w/o nav) -- Findlay, Ohio
jc2bg is offline   Reply With Quote
Old 01-29-2013, 01:30 PM   #6 (permalink)
S is considered both a Sport mode with autmatic ratio selection with the option to select and within reason have the car lock in that ratio. Over all its lower and keeps the engine around 3 grand or 60% load.
I typicalls use S in stop n go traffic. I turn off econ in interstate traffic that varies in speeds from likr 45-70 mph. I havent really found a good use to select a gear, but I do bump the - one in drive when braking to brake harder and get more regen.
