5 min charging for 300 mile range? - Insight Central: Honda Insight Forum
Go Back   Insight Central: Honda Insight Forum > Hybrid and Alternative Fuel Forum > General News Discussion
Old 03-04-2019, 03:15 PM   #1 (permalink)
Default 5 min charging for 300 mile range?
Can this be true?
Pich Automotive, a new electric car startup launched by Toni Pich, a descendant of Volkswagen’s Ferdinand Pich, is unveiling this week an all-electric GT with over 300 miles of range and 5-minute charging enabled by some mysterious new battery cells.
https://electrek.co/2019/03/04/elect...rious-battery/
Sam12345 is offline   Reply With Quote Quick reply to this message
Old 03-04-2019, 04:17 PM   #2 (permalink)
I have been reading about sodium glass batteries that can also do that coming in 2022 . A woman named Bragga is responsible for the break through. And graphene Technology is supposed to be three times better than lithium chemistries. Toyota cars will get first shot at it in 3 more years.
NathanC is online now   Reply With Quote Quick reply to this message
Old 03-04-2019, 05:40 PM   #3 (permalink)
IamIan's Avatar
Good LiFePO4 cells or SCiB LTO cells , with active cooling , can both do the first 0-80% Of charge in ~6 Minutes .. ie ~10C charge rate .. but they should slow down for that last top ~20%.
Accoridng to the linked article .. 0-80% is what they are talking about .. not a full 100% charge.
A ~4,000 Lbs car with ~300 Miles @ ~3miles per kwh means ~100kwh .. in ~5 Minutes would need an average of ~12C rates .. which would be ~1200 kw (aka ~1.2MW) .. which is a crazy amount of power (really big plug/wires) .. like the combined electrical service for about ~30 normal houses worth of power.
But the article claims "The company says that the cells don’t require active cooling" .. for electrical power .. and no active cooling .. no .. that will not be possible .. with Active cooling .. yes.
I only see 2 ways to get that kind of rate, without active cooling:
#1> Battery swap .. which isn't 'charging' .. so shouldn't be described as such.
#2> Flow battery .. so .. it isn't electrical connection to charge .. instead they pump a replacement fluid .. and the fluid carries with it the battery 'recharge' .. but those have (historically) had lots of application problems.
Capacitors could do the charge rate .. but not the ~4,000 Lbs car ~300 Mile range.
I'd be highly skeptical until more information is confirmed by a real world vehicle demonstrating said feature.
  • Life Long: Efficiency&Sustainable Enthusiast
  • oo-MT-I1: MIMA(#024)+FAS+OBDIC&C+HighwaterDashResetButtons+A C CompressorBypass+LiFePO4PHEV~2.5kwhIMA 1p48s +Auxiliary12v~1.6kwh LiFePO4 8p4s+BCM-Fooler+BCM-Interceptor+EVDisplay Meter +420w Solar 120Roof/105Hatch/85Dash/110Hood +RearGazShocks+KLR3CYL Springs F&B+Manual DC-DC +1.3kwAC Charger +LED Headlights +PTC Heat IMA Battery
  • On-Going Projects: Improved EV-Mode+ More Insight Solar+TEG +v2-Li-IMA
IamIan is offline   Reply With Quote Quick reply to this message
Old 03-04-2019, 07:41 PM   #4 (permalink)
Willie Williford's Avatar
If you are interested:
https://en.wikipedia.org/wiki/Glass_battery
Use: 438,000 mi. @ 58.2 LMPG.
Old 03-05-2019, 12:58 AM   #5 (permalink)
More info
http://www.desten.com/news/8
http://english.cas.cn/newsroom/resea...9_188050.shtml
Similar Threads
46 MPG but only 400 mile range??? CSteacher Honda Insight MPG 12 01-21-2017 01:39 PM
Battery Voltage vs. Temp. jime Modifications and Technical Issues 16 12-10-2016 04:46 PM
Forced IMA charging on hill climbs OuttaSight Troubleshooting and Problems 13 01-21-2010 11:14 AM
Project Insight - A real world 1,000 mile range EV? wannab Honda Insight Forum 1st-Gen Discussion 14 04-07-2006 01:47 PM
1,000 mile range Insight based battery electric car clett Honda Insight Forum 1st-Gen Discussion 1 01-19-2004 03:57 PM
