5.8L V12 Ferrari IMA Hybrid - Insight Central: Honda Insight Forum
Go Back   Insight Central: Honda Insight Forum > Hybrid and Alternative Fuel Forum > General News Discussion
Old 11-16-2015, 08:09 AM   #1 (permalink)
Default 5.8L V12 Ferrari IMA Hybrid
I'm working with a team on a project in Holland.
Basically it is a new vehicle built from scratch fitted with a 5.8L V12 Ferrari engine from a 612 Scaglietti. The projected power with modified exhaust is 570hp + 13hp from the IMA LOL
The interest for us it has a HCH1 Civic IMA Motor fitted as a starter and assist unit in between the engine and gearbox.
The rotor has been modified and a plethora of new parts have been designed and accurately made to allow the IMA motor to fit as if in a Civic.
This is one of the reasons I have been working on controlling the IMA motor without reference to the Civic ECM. This project uses a custom ECM for the IC engine which will talk to my little interface box, and then in turn the MCM which will drive the IMA and manage the battery as it does now.
Anyway some photos of the work so far to wet your appetite.
retepsnikrep is offline   Reply With Quote Quick reply to this message
Old 11-16-2015, 09:21 AM   #2 (permalink)
Fascinating project. Beautiful machine work. Can't actually figure out the hub pieces from the picture, but assume that they both adapt the mechanical pieces to the Insight rotor and strengthen it.
One quick question, benefiting another discussion. Is the hub material of the Insight rotor aluminum or other?
2000 MT Citrus(DogBite); 2000 MT Citrus LTO Conversion; 2001 MT(Aeromodded Hypermiler - 134.4MPG); 2006 MT
Old 11-16-2015, 10:56 AM   #3 (permalink)
samwichse's Avatar
So what's the point of adding such a piddlingly small amount of electric power?
Old 11-16-2015, 01:14 PM   #4 (permalink)
3-Wheeler's Avatar
Sam,
I was wondering the same thing??
Jim.
Under-Belly Smoothing Panels:
Tail Extension:
3-Wheeler is offline   Reply With Quote Quick reply to this message
Old 11-16-2015, 01:21 PM   #5 (permalink)
Rainsux's Avatar
What a cool project to be involved in!
Sam
2000 Citrus
Custom Turbocharger System
MIMA #150
BumbleBee Battery
OBDIIC&C Gauge
NM license plate KERS
Alpine Stereo
GAZ rear shocks
2002 Blue getting new engine
Old 11-16-2015, 02:44 PM   #6 (permalink)
The IMA as a light replacement of starter and generator perhaps?
oz42 is offline   Reply With Quote Quick reply to this message
Old 11-16-2015, 05:38 PM   #7 (permalink)
Point is for it to act as a starter generator and be able to maneuver/propel the vehicle at low speed.
Something to do with it the qualifying as a hybrid with advantages for tax etc in Holland.
I believe the rotor is a machined steel casting. I don't know what they have done too strengthen it..
Hope it is over engineered by Honda by a factor of about 10!!! LOL..
Old 11-16-2015, 05:55 PM   #8 (permalink)
Maybe they could make use of your and Hugh-Falls research on the tandem motor/generator.
Old 11-16-2015, 06:21 PM   #9 (permalink)
anything to keep you occupied from making gizmos for the gen 2 insight, later hch, or crz.
Old 11-16-2015, 06:52 PM   #10 (permalink)
Sounds great. Having IMA means to have a lighter flywheel with that IMA "flywheel emulation".
What output would you expect from the IMA motor when it was fed by a bunch of LiPo or LiFePo batteries?
