I modified the starter relay, IMA bypass - Page 3 - Insight Central: Honda Insight Forum
Old 02-04-2019, 04:47 PM   #21 (permalink)
I was able to follow the shorting of the starter relay. It took me a bit to understand what had to be shorted. Once I figured it out I used electrical tape to make sure it stays closed. I upload pictures showing the open contact (see red arrow), the closed contact and then taped up. Thanks to everyone who explained how to short the starter cut relay. My insight starts up right away without delay with no problem.
Danny2001 is offline   Reply With Quote Quick reply to this message
Old 06-18-2019, 11:35 PM   #22 (permalink)
mpg_numbers_guy's Avatar
Garage
Maybe I'm just not seeing it clearly because I haven't taken my relay out yet, but I'm a little confused what needs to be shorted where.
I'll take my relay out tomorrow if I have time to inspect it and see if it's clearer there what needs to be shorted out.
2006 Insight MT, New Formula Red
| When purchased, Nov '18: 254K mi, LMPG 62.5
| Now: 262K mi, 81.6 MPG avg (LMPG 62.9, not reset), best 126.6 MPG
| Full IMA delete, 15V Meanwell pseudo-alternator, increased tire pressure, grille block, WAI, underbody panels, Scott's pan, other aeromods
| 6th gen Civic console, 8th gen Civic shift knob, Polk DB652 speakers, all LED lighting except interior and signals
| Details:
mpg_numbers_guy is offline   Reply With Quote Quick reply to this message
Old 06-19-2019, 07:30 AM   #23 (permalink)
Send a message via Skype™ to Ecky
The relays are 4-pin. When the two that power the coil get 12v, it closes the circuit to the other two. Until this happens, the backup starter cannot run.
I don't recommend it, but you could put a paperclip between the two pins for the starter and it would work.
Silver 2000 5MT -
Ecky is offline   Reply With Quote Quick reply to this message
Old 07-06-2019, 05:12 PM   #24 (permalink)
Default strtr rly pic
when doing this, decided to get a 'macro shot,' hope others can benefit.
File Type: jpg insgt str relay pic4 paint reduced.jpg (639.4 KB, 14 views)
apollos68 is offline   Reply With Quote Quick reply to this message
Old 07-10-2019, 11:14 PM   #25 (permalink)
Linsight Designer
mudder's Avatar
Wait, why not just bypass the relay entirely? You can do this with a single 2" piece of wire with male spades crimped on either end. (Permanently) remove the relay and plug said wire into the connector.
Insight Medic
mudder is offline   Reply With Quote Quick reply to this message
Old 07-11-2019, 07:56 AM   #26 (permalink)
I suggested this months ago.
Silver 2000 5MT -
Old 07-11-2019, 10:54 AM   #27 (permalink)
I trust the relay to stay on and make a good connection for years as it has done more than a piece of wire would.
This is the method I choose and I am sticking to it.
. Warm White or Cool White available!
2000 Insight,
tryingbe is offline   Reply With Quote Quick reply to this message
Old 07-11-2019, 12:58 PM   #28 (permalink)
Linsight Designer
mudder's Avatar
Originally Posted by tryingbe View Post
I trust the relay to stay on and make a good connection for years as it has done more than a piece of wires would.
Sweet, sounds like you have a solution that works for you. I agree it will work; I was just suggesting an alternative option. Glad you found something that works.
Insight Medic
