2002 insight CVT is surging and rpms are going up/down like a TCC disengaging? - Insight Central: Honda Insight Forum
Old 04-01-2019, 01:05 AM   #1 (permalink)
INSIGHTJRNY's Avatar
Default 2002 insight CVT is surging and rpms are going up/down like a TCC disengaging?
2002 insight CVT is surging and RPMs are going up/down like a TCC engaging & disengaging?
Happens at cruise at say 60 mph when my RPMs would normally be at 2400 RPMs but now it hovers around 3000 to 3500, then occasionally drops back to normal 2400 RPMs...
I notice the Instant MPG goes way down from 57 mpg to like 47 mpg when the Rs spike over 3000 RPMs.
Also when I decelerate = lift off the gas pedal, it downshifts to like a lower gear, and the RPMs rise and slows the car down a tad?!?!?
As a result my Full tank MPG went from a normal 570 miles per tank to like 400 per tank..
NOTE: I have already did a Trans fluid service with "Honda CVT trans fluid" around 2000 miles ago and all was fine then, Also I was told there is NO filter is that true? so Im perplexed to say the least
I read somewhere in the forums about a factory reset when disconnecting the battery and driving it up to 37 mph the lift off the gas for 5 seconds also... that didn't work heave sigh..
Any answers to this frustrating problem?
Thank you in advance
INSIGHTJRNY is offline   Reply With Quote Quick reply to this message
Old 04-01-2019, 02:56 AM   #2 (permalink)
Xspeedracer's Avatar
Check fluid level ASAP could be failing from low fluid
Sent from my iPad using Tapatalk
2001 Insight Red 5 Speed
Rear Gaz shocks and Daewoo Matiz springs upgrade
Alpine stereo system upgraded speakers to alpines
Xspeedracer is offline   Reply With Quote Quick reply to this message
Old 04-01-2019, 03:12 AM   #3 (permalink)
Johnmarkzimm's Avatar
I had a similar problem. It was fixed by cleaning the EGR plate.
Johnmarkzimm is offline   Reply With Quote Quick reply to this message
Old 04-01-2019, 04:58 PM   #4 (permalink)
Yes I did a service not long ago 2000 miles age and its full so im worried here...
Old 04-01-2019, 04:59 PM   #5 (permalink)
Did that when i first got the car and it was clean as a whistle
Old 04-01-2019, 05:13 PM   #6 (permalink)
Rainsux's Avatar
Originally Posted by INSIGHTJRNY View Post
Yes I did a service not long ago and its full so im worried here...
How long ago was the fluid changed, and what color is it? Did they use Honda CVT fluid?
EDIT: I just saw your post about this. Yes, there are two filters.
Sam
2000 Citrus
Custom Turbocharger System
MIMA #150
BumbleBee Battery
OBDIIC&C Gauge
NM license plate KERS
Alpine Stereo
GAZ rear shocks
2002 Blue getting new engine
Old 04-01-2019, 06:25 PM   #7 (permalink)
Willie Williford's Avatar
Apparently you don't accept PM's, so Please include your location in your profile, as ALL G1 Insighters have done. Thank you.
Use: 438,000 mi. @ 58.2 LMPG.
Old 04-01-2019, 07:38 PM   #8 (permalink)
Hi Willie,
No i haven't fully setup my profile with info yet but I'm from Modesto Ca.
Is there a setting to receive PMs im not aware of?
J
Old 04-01-2019, 07:41 PM   #9 (permalink)
Default Yes it's Honda CVT trans fluid I had to buy
Sam
Yes it's Honda CVT trans fluid I had to buy and did it maybe 2000 miles ago. the fluid seems clear and we just drained and filled the trans.
Where are these 2 filters located???
J
Old 04-01-2019, 08:15 PM   #10 (permalink)
I made a few videos of them.
https://www.insightcentral.net/forum...s/24023?page=2
Tags
cvt, slippage, surging, tcc
Similar Threads
CVT Problems? Car is surging and rpms are going up/down iibbmm Problems and Troubleshooting 6 07-17-2005 09:51 AM
