2006 MT Grid Chargers - Insight Central: Honda Insight Forum
Old 06-02-2019, 08:17 PM   #1 (permalink)
Imamatthews's Avatar
Default 2006 MT Grid Chargers
What do most Insight folks use, the Max Volts brand? They will not tell me the charge current spec!! WOW!! Are they the way to go?
Imamatthews is offline   Reply With Quote Quick reply to this message
Old 06-02-2019, 08:26 PM   #2 (permalink)
Willie Williford's Avatar
My recommendation:
https://hybridautomotive.com/products/
Use: 438,000 mi. @ 58.2 LMPG.
Old 06-02-2019, 08:41 PM   #3 (permalink)
RabbitCVT's Avatar
Garage
I use a Maxx Volts charger. It works great and I haven't had any problems with it. They are also much cheaper than other chargers. They aren't as user-friendly as others, but as long as you know what you're doing it's fine. They do have fairly good customer support too. I just charge for 24 hours, then discharge to about 90v, then repeat. Hope this helps
RabbitCVT is offline   Reply With Quote Quick reply to this message
Old 06-03-2019, 02:49 AM   #4 (permalink)
eq1
https://power.sager.com/lpc-100-500-3931687.html
Or this for lower 350mA: https://power.sager.com/lpc-100-350-3931686.html
2000MT, CANADIAN
Old 06-03-2019, 07:10 PM   #5 (permalink)
I'm not quite as bright as the average bear. Are you saying that you attach this power supply to your IMA to charge it? And I assume if you do that you would be keeping a pretty close eye on the voltage in the battery. Is this what you are doing?
2009 Honda Fit
1987 CitroŽn 2CV
2001 MT Honda Insight, 132K miles at time of purchase, 164K now
boojum is offline   Reply With Quote Quick reply to this message
Old 06-03-2019, 09:42 PM   #6 (permalink)
eq1
Originally Posted by boojum View Post
...you attach this power supply to your IMA to charge it?
Yes.
And I assume if you do that you would be keeping a pretty close eye on the voltage in the battery?
Not any more than you'd do with any of the 'vendor' chargers. I do run my fan with the OBDIIC&C though. If you didn't have one of those you'd need an extra 12V supply to power the fan.
2000MT, CANADIAN
