$290 for insight EGR valve - Insight Central: Honda Insight Forum
Old 09-16-2014, 03:32 PM   #1 (permalink)
Default $290 for insight EGR valve
This is what the dealer quoted me. My Civic only cost $190 so I wonder why the price is so hugely different? Any ideas?
Personal Lifetime MPG:
~90 the original Insight (retired)
80+ Civic Hybrid (manual)(lean burn)(retired)
70+ Prius G3
theaveng is offline   Reply With Quote Quick reply to this message
Old 09-16-2014, 03:35 PM   #2 (permalink)
jealous1shateric's Avatar
Less insights produced. I have a used one for sale contact me [email protected]
Los Reciclao
@bolacan413
@k_insight
jealous1shateric is offline   Reply With Quote Quick reply to this message
Old 09-16-2014, 05:36 PM   #3 (permalink)
Premium Member
Balto's Avatar
You can also use 1999 Honda Accord EGR, or 1999-2004 Honda Odyssey EGR. The Odyssey EGR can be had at orileys for 65$.
Balto is offline   Reply With Quote Quick reply to this message
Old 04-14-2019, 12:05 PM   #4 (permalink)
Different Honda part numbers. Can I get confirmation before I order a new EGR?
kfree2 is offline   Reply With Quote Quick reply to this message
Old 04-14-2019, 01:50 PM   #5 (permalink)
It's been confirmed to work. May in fact be better. It's not identical but it bolts up and works.
https://www.insightcentral.net/forum...t-insight.html
2001 Gen 1 Insight MT w/Homebuilt Grid Charger + Expertfabricator Subwoofer + GAZ rear shocks + Bumblebee Battery
ackattacker is offline   Reply With Quote Quick reply to this message
Old 04-14-2019, 02:10 PM   #6 (permalink)
Thanks - I found the longer thread on this subject and ordered the Accord valve. I see it has the smaller opening, but have heard the success stories and am looking forward to replacing my 250K-old unit - I already cleaned the plate.
Old 04-14-2019, 04:39 PM   #7 (permalink)
I see you are in New York, which is not so far from me.
This winter I built an EGR valve tester that does not require the valve to be removed and measures sensor position vs current applied, and can surface intermittent valves. I hope, at the east coast maintenance event in June, to test a number of valves and see if there is a correlation between brand, age, etc. I think that the failure modes are gradual and include the sensor getting intermittent and one I don't think we've talked about: internal friction giving different values for the same position whether the valve is opening or closing. There is a fix for the intermittent sensor, but after doing it on mine, I retested it and found it getting "noisy" again.
Unless life stops me, I will also be attending the Ohio event in September and will bring my tester. It would be really cool to get measurements on a bunch of valves and characterize the different replacements available.
Please ask your mechanic to return your old valve to you, so that we can measure it sometime in the future. Perhaps write on the side of it the mileage when it was replaced.
2004 MT Red, 143K miles "new", ~160K now
2003 CVT Silver, 181K miles "new", 181K now
*sean* is offline   Reply With Quote Quick reply to this message
Old 04-14-2019, 05:35 PM   #8 (permalink)
I'll do the swap myself, so will keep the old valve. Not sure if I'll be making any meets, but if you are in the Hudson Valley...
Old 04-15-2019, 02:15 AM   #9 (permalink)
Send a message via Skype™ to DaBossk
What are the symptoms of a bad egr valve? My cvt insight has always had a little shudder which apparently POSSIBLY could be the egr valve? It doesn't shudder too bad but I'm at 215k miles right now and my egr valve is probably original.
DaBossk is offline   Reply With Quote Quick reply to this message
Old 04-15-2019, 07:35 AM   #10 (permalink)
SSSSSS's Avatar
I just ordered a new valve from Partsgeek. Car has just shy of 160k on it with what I would presume is the original EGR Valve. Life time MPG is 53.1 which is not the greatest. Here in New York you have to deal with hills and cold weather. I will post the results.
2000 Insight MT/AC 138k
1991 CRX SI
SSSSSS is online now   Reply With Quote Quick reply to this message
