2010 Insight Spark Plugs - Insight Central: Honda Insight Forum
Old 03-12-2017, 04:36 PM   #1 (permalink)
Default 2010 Insight Spark Plugs
I am almost at the 200 thousand km mark.
I was looking at spark plugs options and noticed many options like in link below:
2010 HONDA INSIGHT Spark Plug Parts
Any idea which would be the best option and when is it usually recommended to change the spark plugs?
Thanks
Moota is offline   Reply With Quote Quick reply to this message
Old 03-26-2017, 04:25 AM   #2 (permalink)
gms24ru's Avatar
Honda recommended spark plugs for Honda Insight G2:
  1. DILFR6F11G NGK
  2. VFKH20, 12290-RBJ-003, DENSO
But VFKH20 no longer available, replacement by DENSO IKH20TT.
You need 8 spark plugs.
Honda Insight II 2010 RHD Silver G-Edition Japan
Electric Train H710MK124RU Japan-Krasnoyarsk
Telegram:
gms24ru is offline   Reply With Quote Quick reply to this message
Old 09-14-2018, 03:15 AM   #3 (permalink)
I've been searching and it seems that NGK as of last year came out with the Iridium RX Ruthenium series. The replacement for stock 12290-RBJ-003 (DILFR6F11G) or Denso's VFKH20 from the NGK's Iridium RX Ruthenium is LFR6AXR-11P. Slightly pricier but check out the specifications for its service interval: 100,000km + 20%.
If anyone has used the Denso VFKH20 or the LFR6AXR-11P, kindly comment. Thanks.
halcyon27 is offline   Reply With Quote Quick reply to this message
Old 09-16-2018, 02:42 PM   #4 (permalink)
Is there a disadvantage to simply buying genuine Honda spark plugs?
hot_desert is offline   Reply With Quote Quick reply to this message
Old 09-16-2018, 05:54 PM   #5 (permalink)
Willie Williford's Avatar
Money is the only disadvantage? Buy from a dealer at a more expensive price.
Use: 438,000 mi. @ 58.2 LMPG.
Old 09-16-2018, 06:03 PM   #6 (permalink)
How do aftermarket spark plugs compare in quality? Do most people seem to have good experiences with them?
2010 Insight; 100,400 miles as of July, 2018; ContiPremiumContact 2 tires
Old 09-18-2018, 03:14 AM   #7 (permalink)
Hot Desert, you are technically right, there is only one NGK model of plug that is right for out Insights. You can search for that part number online, there is no reason to get them through a dealer. Just be aware that, because they are so expensive, there are fakes out there. So a killer deal on Ebay may not be such a good idea.
Also, like I think I have told you, several of us have waited without issue. The plugs that came out of my wife's 2010 Insight at 130k were perfectly good and changing them made no difference in fuel economy or how the engine ran.
You may read about fouled plugs around here, but that is because the 2012-2013 (maybe into 2014 as well) have piston rings that leak oil into the combustion chamber. there is a warranty extension on those cars.
Old 09-25-2018, 10:01 PM   #8 (permalink)
Hi how to know if my car has this leak in chamber problem instead of a faulty old spark plugs? Appreciate a speedy reply, Thank you
drkol95 is offline   Reply With Quote Quick reply to this message
Old 09-25-2018, 11:00 PM   #9 (permalink)
Contact your local Honda dealer and he can run your Vin. number for that malfunction.
Old 10-02-2018, 05:43 AM   #10 (permalink)
gms24ru's Avatar
VFKH20 discontinued due to new technology.
In the spring I set spark plugs DENSO IKH20TT when adjusting the valves, mileage was 100K kilometers. Old NGK in the photo.
Together with the replacement of the fuel filter is now consumption is 20.2 kilometers per liter.
Telegram:
