90,000 mile maintenance? - Insight Central: Honda Insight Forum
Old 07-06-2017, 08:57 AM   #1 (permalink)
Default 90,000 mile maintenance?
my car just recently hit 90,000 miles, oil is at 40%, can't find anything on the regular scheduled maintenance since all the book will say it's "please wait until the remainder light indicator."
What is the usual 90,000 mile maintenance on the insight?
u_hsen is offline   Reply With Quote Quick reply to this message
Old 07-06-2017, 09:58 AM   #2 (permalink)
jcbesq's Avatar
normal maintenance is all that's required unless of course you'd like to do the 100k mile maintenance early
JB
2011 Insight LX - 78k miles
jcbesq is offline   Reply With Quote Quick reply to this message
Old 07-06-2017, 11:06 AM   #3 (permalink)
so whats considered as normal maintenace?
oil change
tire rotation
Old 07-06-2017, 01:01 PM   #4 (permalink)
Because you failed to fill out your profile, I don't know what country you are in. It matters because how the maintenance is indicated varies. Here in the U.S. the maintenance minder will set codes that correspond to what should be done.
Here's a PDF of those pages from a Honda owner's manual:
http://techinfo.honda.com/rjanisis/p...707G00016A.pdf
What year is your Insight?
If it is new to you, once it hits 15% or so I would:
Change oil & filter
Rotate tires (this really is a brake inspection)
Change the transmission fluid (use only Honda CVT fluid)
Replace the engine and cabin filters.
Once it hits 105-110k the spark plugs are due. There are 8 of them and they are really expensive. Also, valves may be adjusted if noisey.
There is no timing belt, it's a chain. I think there is a drive belt that should be changed. (For the A/C there is no alternator, the IMA motor does the charging)
Old 07-06-2017, 01:55 PM   #5 (permalink)
in the USA,
yah i did the transmission myself at 87000, i guess just the filters now.
Old 07-07-2017, 01:14 AM   #6 (permalink)
What year is your Insight? Because if it is a 2012 or 2013, it may be subject to excessive oil consumption.
Old 07-07-2017, 10:27 AM   #7 (permalink)
my insight is 2011, any "flaws" in this year?
Old 07-07-2017, 11:44 AM   #8 (permalink)
Nope, none that have emerged so far. All 2010s and some early build 2011s have software updates available at a Honda dealer. The manufacturing date is on the door sticker.
Location (Required)
Where you live
