330 CCA vs. 500 CCA battery? - Insight Central: Honda Insight Forum
Old 10-29-2017, 09:00 PM   #1 (permalink)
Default 330 CCA vs. 500 CCA battery?
When buying a new 12 volt battery to start the insight, are their any cons to buying a 500 cold cranking amp battery vs a 330 cold cranking amp battery? (I believe the original equipment battery was around 330 cold cranking amps)
Please assume the physical size of the batteries are the same, and the price of each battery is the same.
Thanks!
Ultraboy is offline   Reply With Quote Quick reply to this message
Old 10-29-2017, 09:04 PM   #2 (permalink)
Go with the extra cranking amps, better in the long run and winter coming up.
Honda hybrid442 is offline   Reply With Quote Quick reply to this message
Old 10-29-2017, 09:11 PM   #3 (permalink)
S Keith's Avatar
Generally higher CCA means higher overall capacity, so it makes sense to pick higher CCA.
Given that the 12V does not usually see starting loads, CCA isn't that important. I would put more emphasis on capacity than CCA.
Honda's "unique" charging system also works better with higher capacity batteries as they tend to last longer.
'05 G1 CVT w/192K mi as of 7/2016; '02 G1 CVT w/182K mi as of 7/2016 (P1449 HR pack)
