2011 OEM Headlight Specs and best options - Insight Central: Honda Insight Forum
Old 04-27-2018, 10:13 PM   #1 (permalink)
Default 2011 OEM Headlight Specs and best options
Hello Everyone,
Anyone have the exact specs for the headlights. Was gonna bump them up a bit if a decent bulb swap is available. Was mainly looking to keep the same color and just boost wattage or go LED.
Thanks in Advance!
Damon808 is offline   Reply With Quote Quick reply to this message
Old 04-28-2018, 08:13 AM   #2 (permalink)
RedDevil's Avatar
You need H11 lamps for the low beams.
I'd be careful putting anything over 55 Watt in, as the extra heat may cause trouble.
HIDs are the easy solution, a set of 35 Watt HIDs can be had in any color (around 3400K is about the same color as halogen, just at 3 times the brightness).
Cheap LEDs often fail prematurely, and the better ones have bulky fans or cooling grids on the back which may take too much space and make fitting them a hassle.
China sells cheap HIDs for ridiculously low prices, but they often don't have proper H11 plugs just metal prongs that you can shove into the H11 connector. If that bothers you you may get a set with proper connectors or buy and mount the connectors yourself.
Shipping is usually free but may take a month.
Have a set of spare lamps; they are cheap and shipping takes long. One of mine failed after 500 hours of use, but its replacements have thousands of hours on them with no trouble whatsoever.
HIDs are no good for the (9006) high beams as HIDs take time to get to full strength. No such thing as flashing oncoming traffic for attention.
2011 Insight Elegance
Accord horn, Waxoyl, HIDs, Green Oil, UltraGauge, LEDs, full upper&partial lower grille block, aero tweeks, plans for several eco mods
RedDevil is offline   Reply With Quote Quick reply to this message
Old 04-29-2018, 04:54 PM   #3 (permalink)
Engine-Off-Coast
Natalya's Avatar
For the low beams I have these LEDs and they are fantastic:
https://www.superbrightleds.com/more...ink/4445/9995/
I went with no filter on them.
LED on the right, regular on the left.
Natalya is offline   Reply With Quote Quick reply to this message
Old 05-02-2018, 08:03 PM   #4 (permalink)
buy hid trust dont wana explain but it has a longer distance of light vs led. led just looks bright up close but is poor far away
Ali2627 is offline   Reply With Quote Quick reply to this message
Old 05-03-2018, 06:01 AM   #5 (permalink)
Default Many Thanks!
Guess its time to research Halogen vs LED as in Hawaii I cant use HID unless they are stock on vehicle.
Appreciate the "Insight!" Pun intended.....
Old 05-06-2018, 11:44 AM   #6 (permalink)
How long have you been using them?
Have you noticed any lumen loss as they age?
LoNOx 1
2010 Insight II
2013' Ford F150
2000 Roush Mustang Convertible
LoNOx 1 is offline   Reply With Quote Quick reply to this message
Old 05-06-2018, 11:48 AM   #7 (permalink)
Compared to HID's in what I was driving to work, the stock Insight lamps are puny. I have a 48 miles commute that is a virtual gauntlet of wildlife to avoid. I leave for work at 4am and bright lights are important. I drove my daughter's new 18' Prius eco last night with LED's and it lit the highway very well.
LoNOx 1
2010 Insight II
2013' Ford F150
Location (Required)
Where you live
