Loud rear brake noise - Page 2 - Insight Central: Honda Insight Forum
Old 05-11-2019, 05:19 PM   #11 (permalink)
I have the same kind of issue on my 2001 MT. I got concerned because they were getting noisy all of a sudden. Just took the drums off this hour and saw the brake shoes looked ok. The drum might be worn since they have worn into the drum about maybe 1/32. It has one new wheel cylinder from 12/18. The brake line ruptured and one cylinder was so corroded they needed to replace it in order to connect the new lines.
Here's hoping it's a self-adjustment issue.
Abunker11 is offline   Reply With Quote Quick reply to this message
Old 05-11-2019, 05:46 PM   #12 (permalink)
So I measured the pads and they are 3mm which is fine. The wear in the drum is minimal. I can barely feel the difference between worn and not worn metal. I wonder why the pads being out of adjustment would cause them to become noisy? It's worth a try anyway using Willie W's parking lot adjustment method. Otherwise I'm going to suspect my much newer front disc brakes.
Old 05-12-2019, 09:10 AM   #13 (permalink)
So I think my right rear brake system might have some issues. Upon comparing right and left I am thinking right side is suspect. What do others think?
Is this drum brake shoe bad. It looks pitted to me but don't have much experience.
https://drive.google.com/file/d/1iWI...ew?usp=sharing
The right side drum seems to have some grooves worn and also dark markings that are perpendicular to the shoe wear.
https://drive.google.com/file/d/1GDq...ew?usp=sharing
Old 05-14-2019, 07:00 PM   #14 (permalink)
Looks like brand new parts. Let them wear them in a bit and see if the noise goes away.
The perpendicular lines might just be from being left with the parking brake on for a long time, or with some water in the drum. Again, should polish out with a bit of use.
kalmar is offline   Reply With Quote Quick reply to this message
Old 05-15-2019, 05:31 AM   #15 (permalink)
That is good to hear. Thanks. I noticed some contact between the drums and rust that had built up on the backing plate. I chipped the worst parts off which stopped some of the grinding noise when I turned it by hand. I also cleaned out a bit of sand and fair amount of powder with a rag. I've read to never use compressed air due to the hazards of breathing the dust. I also tried adjusting the DB by backing up rapidly and applying the brakes. Not sure if that helped but I think overall they are quieter.
My front disc brakes are 2 years new and the right side looks good. The left side wheel was torqued down so hard during the brake job that I haven't gotten it off. Is it ok to use a torch on tire nuts?
Old 05-15-2019, 10:50 AM   #16 (permalink)
Willie Williford's Avatar
Spray the lug with some good looseing oil. 80 ft pounds of torque on the lug nuts. Get a breaker bar and use an extension if needed.
Use: 436,000 mi. @ 58.2 LMPG.
Location (Required)
Where you live
Similar Threads
Loud noise with Auto AC full on Insightlover2011 Honda Insight Forum 1st-Gen Discussion 0 05-04-2015 09:15 AM
cvt transmission loud grinding noise chirrin Problems and Troubleshooting 14 07-22-2013 06:05 AM
HELP Loud metal grinding noise from engine (Video) randomfire Problems and Troubleshooting 36 06-04-2013 03:30 PM
Loud whirring noise minknower Problems and Troubleshooting 11 09-10-2012 12:09 AM
Loud Engine Sound When Recharging JPBGATOR Problems and Troubleshooting 4 07-09-2006 08:49 PM
