2010 Honda Insight oil change. - Insight Central: Honda Insight Forum
Old 02-16-2019, 02:15 PM   #1 (permalink)
NickDalton's Avatar
Default 2010 Honda Insight oil change.
So I went to change the oil in my Insight for the first time, I couldnít get the drain plug off. I tried everything I could think of. Iíve got an impala that I drove before I got my Insight, so I know how to change the oil. Iím about 65 miles over due for an oil change and Iíve got to make 100 mile trip in an hour, so I donít really have time to try and get it off today, Iíll have to do it tomorrow as long as it isnít raining. But do you guys think it would be okay to make a 100 mile trip a little overdue on oil? Oh I did replace the oil filter, I was hoping to release suction or something, but it didnít work. Thanks!
-Nick
Sent from my iPhone using Tapatalk
NickDalton is offline   Reply With Quote Quick reply to this message
Old 02-16-2019, 02:36 PM   #2 (permalink)
jcbesq's Avatar
Youll b fine ... i assume the oil thats in there is the synthetic or green oil 0w20 ... its pretty robust oil ... im amazed how clean my oil looks after 10k miles
As for the troublesome drain plug, use a breaker bar over the wrench ... dont worry about destroying it ... theyre cheap and so are the washers and u wont ,mess up the threads so long as the increased pressure is even and in the general plane of the threads
JB
2011 Insight LX - 78k miles
jcbesq is offline   Reply With Quote Quick reply to this message
Old 02-16-2019, 03:01 PM   #3 (permalink)
NickDalton's Avatar
Thanks for the hasty reply, I feel like they used something like an impact gun to put it back on. I even tried sticking the ratchet on there and using a foot to break it loose but that didnít work either.
Old 02-16-2019, 03:02 PM   #4 (permalink)
NickDalton's Avatar
I picked it up from a dealership for 6000 they didnít say that they changed the oil, but they didnít say they didnít either. I picked it up the moment it rolled out of inspection. So I assume they changed it. I feel like they would have went by the book since it was a dealership then again, who knows
Old 02-16-2019, 07:21 PM   #5 (permalink)
jcbesq's Avatar
Check ur dipstick for color and smell .... which incidentally is good dating advice too
JB
Old 02-17-2019, 12:49 AM   #6 (permalink)
This is the reason the directions call for a fresh drain plug washer and a torque spec. They are like 30 cents each and the torque spec is 33 lbs.
https://www.handa-accessories.com/insight2010.html
Once you get back, do the CVT fluid as well. That drain has a crush washer as well, but a different size. 18mm for the trans, 14 mm for the engine oil.
See this thread:
https://www.insightcentral.net/forum...id-change.html
Similar Threads
2010 DIY oil change ? photosenior Modifications and Technical Discussions 5 08-05-2016 03:36 PM
How to change the HMMF oil in insight 2010 mervin Troubleshooting and Problems 6 05-22-2015 03:22 AM
Trustworthy Oil Change in South Florida? Change oil filter from the top? Insight_Bob Honda Insight Forum 1st-Gen Discussion 3 05-13-2014 06:33 PM
You change oil filter at every oil change thekanuk Honda Insight Forum 1st-Gen Discussion 18 10-01-2013 04:34 PM
2000 is louder after oil change, air filter change and master brake cylinder replaced JQHeller Problems and Troubleshooting 5 06-30-2011 10:34 AM
