40 mpg? - Insight Central: Honda Insight Forum
Old 06-12-2018, 04:21 AM   #1 (permalink)
Default 40 mpg?
I purchased a 2013 Insight back in March that had about 44K miles on it and the car is in really good shape however, I'm not getting the mileage I anticipated. I do practically ALL highway driving and when I filled my tank yesterday, I had traveled 310 miles and the car took 8.1 gallons of fuel. That's roughly 40 MPG. And that's highway. I am running the AC but does that make that much of a difference? Also, my range indicator said that I only had 35 miles left but yet it only took 8 gallons of gas. Is this typical? Can I count on an additional 70 to 80 miles after the range indicator says I'm at 0?
Cheech is offline   Reply With Quote Quick reply to this message
Old 06-12-2018, 05:50 AM   #2 (permalink)
85mph?
Your car is only rated at 41/44, so 40mpg would be normal if you are drive above the speed limit.
. Warm White or Cool White available!
2000 Insight,
tryingbe is offline   Reply With Quote Quick reply to this message
Old 06-12-2018, 08:20 AM   #3 (permalink)
Send a message via Skype™ to Ecky
Wrong forum. You have a 2nd generation Insight.
A/C makes a difference. I find I lose 10-20mpg on my Insight - can be from 80-100mpg down to 70-80mpg at the same speed.
If you want to improve economy, slow down. Reducing speed dramatically improves fuel economy. Also, add air to your tires. I run about 45PSI in mine, but some members on here run 60PSI or even as high as 100PSI in the case of one particularly interesting case. It's diminishing returns above 45-50, but the difference is dramatic between, say, 30 and 45.
Silver 2000 5MT -
Ecky is offline   Reply With Quote Quick reply to this message
Old 06-12-2018, 10:21 AM   #4 (permalink)
Rainsux's Avatar
Thread moved to 2nd Gen.
Sam
2000 Citrus
Custom Turbocharger System
MIMA #150
BumbleBee Battery
OBDIIC&C Gauge
NM license plate KERS
Alpine Stereo
GAZ rear shocks
2002 Blue getting new engine
Old 06-12-2018, 12:36 PM   #5 (permalink)
jcbesq's Avatar
A/C and building summer heat also exact a goodly percentage off mpg
JB
2011 Insight LX - 78k miles
jcbesq is offline   Reply With Quote Quick reply to this message
Old 06-13-2018, 03:41 PM   #6 (permalink)
Yes. See here:- https://www.insightcentral.net/forum...100-miles.html
MPG on the insight suffers badly at very high speeds. I can see similar MPG to you when I drive at 85-90mph.
booke23 is offline   Reply With Quote Quick reply to this message
Old 10-20-2018, 02:22 PM   #7 (permalink)
Default 1st post
have 2014 insight going on 3 years now, getting 41mpg's consistently...just turned over 9000 miles recently. don't drive far leave a/c on all the time, think it gets better that way...don't see drop off...don't drive if there is any salt on the road, have 4wd for winter, gets about 14mpg's ,,,hate to fill up costs $50...hope to get good insight from insight forum in the future.....
mikeal21 is offline   Reply With Quote Quick reply to this message
Old 11-23-2018, 02:07 PM   #8 (permalink)
Rw1229's Avatar
I’ve had a lifetime avg of 49-50 mpg with my 2010 Insight EX Nav (96K miles), and it takes dedication and a strategy to get that. Avoid short trips/errands- those kill mileage. Choose routes that you can maintain long stretches of steady speed @40-55 mph (that isn’t always freeways) and anticipate stops/traffic lights in advance to coast in. If on freeway, find a vehicle going at slower to speed to follow so traffic is not blaming you. 🙂 Never compromise safety for mileage though. Best way to get “feel” for high mpg driving is using the instant mpg reading on Driver Info Center. See how much difference a “feather “ touch change in pressure affects it by trying to keep bar to the right of the 50mpg indicator. Hope this helps.
Rw1229 is offline   Reply With Quote Quick reply to this message
Old 01-25-2019, 07:00 PM   #9 (permalink)
2011 insight .
When my car read 0 range it takes 9 gallons. So 1.6 gallons remain. Figure 60 miles range remain. AC reduces by about 4 mpg. I only get 35mpg if I have luggage in trunk and a bikerack and bike hanging ofg the back. Sometimes trip computer gives wacky results. Usually get 3 mpg worse than it says.
Sent from my LGMP260 using Tapatalk
Insightfull2011 is offline   Reply With Quote Quick reply to this message
Old 02-28-2019, 01:43 PM   #10 (permalink)
Foresight's Avatar
It's gotta be speed, low tire pressure, non Low Rolling Resistance tires, big loads, wrong oil in the crankcase, bad alignment, bad gasoline, dragging brake, bad 12v battery, big head winds? A combination of some or all?
I just did a 53 mile trip into South Portland, Maine yesterday in single number temperatures above zero. I reset the trip/mpg because it was so cold and wanted to see what the Insight display would indicate. Ended up going in via interstate at 67 mph and returned on back roads 45 to 55 mph. It's a pretty hilly route both ways and there was a little bit of a southeast wind that I bucked on the way down the interstate.
Ended up with and indicated 49.9 mpg reading which would put it in the 47-48 mpg real world range. I inflated my tires last week to cope with the expected cold air, so pressures were probably 37 psi front and 36 psi rear. I have OEM tire sized Firestone Champion Fuel Fighters that have allowed the same MPG numbers that the original Bridgestones produced.
The lowest MPG numbers I've ever measured on my 2013 Insight is about 47. That was in dead of Winter. Spring-Summer-Fall numbers consistently stay 52-57 mpg. Those figures are trip measured miles traveled to fuel added to tank at fill up. Not the MID indicated MPG.
So I don't quite understand 40 mpg, even with the A/C running.
2013 Honda Insight EX Non Navi Taffeta White
2011 Toyota Prius Solar/Sunroof, Sold March 2019
2014 Mini Roadster S, Manual, White Silver, Smile Induction Module
Foresight is offline   Reply With Quote Quick reply to this message
Location (Required)
Where you live
