5 speed transmission oil change - Insight Central: Honda Insight Forum
Old 10-23-2018, 08:29 PM   #1 (permalink)
Default 5 speed transmission oil change
I had a quick question regarding a transmission oil change. I purchased 2 quarts from honda and started the drain/refill process per the manual. I raised my insight by the driver side by the door only using a jack and stand. When I removed the fill plug first, a lot of oil started pouring out. Then I removed the drain plug and finished draining the rest. Now, when I went ahead and started refilling and emptied both bottles, I removed the fill hose I had attached and some oil poured out but I screwed in the plug before anymore could pour out. Iíd say no more than maybe 1/4th of the bottle managed to pour out before I screwed in the bolt. My question is, is my transmission okay? Did I overfill or underfill? I wasnít sure having it on an awkward incline could be an issue with how much I was supposed to fill or how much managed to drain out before I could rescrew in the bolt. Per the manual, I know itís supposed to be leveled with the ground so Iím wondering if thatís another factor too.
I did drive the car for a couple of blocks and the shifter felt butter smooth so thatís a plus, Iím just afraid of any long term effects.
mchacon8924 is offline   Reply With Quote Quick reply to this message
Old 10-23-2018, 09:27 PM   #2 (permalink)
Car needs to be level
Sam12345 is offline   Reply With Quote Quick reply to this message
Old 10-23-2018, 11:15 PM   #3 (permalink)
When the car is level on the lift we use about 1.7 quarts.
Scott
Silver 2000, MT 160,000mi, RE92's, S2000 leather steering wheel
Silver 2002,CVT 187,000mi
Blue 2002,MT 126,000mi, RE92's, S2000 leather steering wheel
Red 2002,MT 196,000mi, RE92's, new rear springs, GAZ shocks
Citrus 2000,MT 182,000mi, MIMA, RE92's, S2000 leather steering wheel, Japanese seat covers.
Simple grid charger SC03
New rear coil springs available, PM me.
One piece aluminum underbody panels.
PayPal:
KLR3CYL is offline   Reply With Quote Quick reply to this message
Old 10-24-2018, 12:18 AM   #4 (permalink)
Iím sure Iím fine but I get pretty paranoid when it comes to working on my car. Iíll buy a bottle to be on the safe side tomorrow and loosen the fill bolt and have the car flat, then remove the bolt from above and top it off with my fill hose. From what the manual says, the oil level is supposed to be right at the edge of the fill hole.
Old 10-24-2018, 01:20 AM   #5 (permalink)
Yes it is supposed to be at the bottom of the fill hole. When you fill it, you do so until it starts to dribble. Once it stops dribbling you put the fill plug back in.
Scott
PayPal:
Old 10-25-2018, 07:26 PM   #6 (permalink)
Drive the front up on ramps and jack up from one rear lift point until level.
atikovi is offline   Reply With Quote Quick reply to this message
Old 10-25-2018, 09:20 PM   #7 (permalink)
Your trans was overfilled, and you probably overfilled it again. I only used 1.4ish quarts from a drain and fill, on level ground. I gained significant mpg because the previous owner on that car had overfilled.
Number81 is offline   Reply With Quote Quick reply to this message
