Toyota MGR? - Insight Central: Honda Insight Forum
Old 06-10-2019, 04:50 PM   #1 (permalink)
Default Toyota MGR?
I've been trying to look around the forums to see if was anyone discussing it, but I couldn't find anything. I'm curious if anyone has played with the idea of using a Toyota MGR. They are found in the back of the Lexus RX400h/RX450h and the Toyota Highlander Hybrid, both utilizing a 288v battery pack.
Is this just something too difficult to control or power? Just curious since I only came across one person playing around with one a few years back.
https://endless-sphere.com/forums/viewtopic.php?t=78540
The specs on the motor:
Weight: 40kg (88lbs)
Max Power: 50kw (68hp)
Max Tq: 140Nm (103ft-lb)
Type: Permanent magnet motor
Max Volts: AC 650v
Gear Reduction: 6.859:1
Edit: I forgot to mention that the MGR is a self contained motor with a differential and gear reduction built into the side housing with axle stubs coming out. The gear fluid is self contained, but doesn't look hard to tap to add a cooler for the setup.
My Daily: 2000 5MT no A/C
My Project Car: 1985 Celica V6.
Sigma Projects is offline   Reply With Quote Quick reply to this message
Old 06-10-2019, 07:51 PM   #2 (permalink)
What are you thinking of doing with it?
2004 MT Red, 143K miles "new", ~158K now, 2014 battery - rescued from the wrecker and humming along happily!
*sean* is online now   Reply With Quote Quick reply to this message
Old 06-10-2019, 08:45 PM   #3 (permalink)
That looks like a fantastic pure EV motor. I wonder what the gearing is like and is it efficient running at highway speeds?
OR, how about an AWD insight!
HiSPL is offline   Reply With Quote Quick reply to this message
Old 06-11-2019, 02:59 PM   #4 (permalink)
Paula and Sabrina (from EcoModder) have wired one up to their DIY controller and drove around, think they put the project notes on endless sphere
Yep in your initial post
https://endless-sphere.com/forums/vi...p?f=34&t=78540
https://ecomodder.com/forum/showthre...mgr-29878.html
Also I think the mgr under an Insight is the most likely path forward to EV
I strongly recommend looking for a Prius AWD at a wrecker, could be interesting
File Type: png D34DCAF8-48E2-4136-AC09-C490CAEC8931.png (526.8 KB, 11 views)
rmay635703 is offline   Reply With Quote Quick reply to this message
Old 06-11-2019, 05:21 PM   #5 (permalink)
Weight cooling speed
Itís small, light and efficient but likely would overheat used as a highway troller
Old 06-11-2019, 10:13 PM   #6 (permalink)
I think it would be quite fun to have one in place of where the spare tire is.
The gearing on the one I posted is 6.859:1. The image rmay635703 posted shows for the AWD prius it has a 10.487:1 ratio.
I've read about concerns about overheating while running continuously, but many have suggested tapping in an oil cooler which is completely doable, I've done it with other differentials. I like it because it's relatively inexpensive, it is a complete unit and not overly powerful but seems powerful enough to match that of the ICE of the Insight.
Oh I didn't know about the Prius AWD. I will check out the comodder forum link.
It’s small, light and efficient but likely would overheat used as a highway troller
I think cooling it might not be as big of a problem, but it seems like trying to run an electric motor at freeway speeds is less efficient than just running an ICE. Like how Honda has setup their current Insight with the single gear engagement for the engine at freeway speeds. But hill climbs, short bursts, etc. sounds like it would be amazing. And because of how light our cars are it probably could work as a low speed EV mode option.
Edit: Second look at the rear motor in the AWD Prius it doesn't look that great for what I'm interested in as what I'm reading is that Toyota added that feature to the Prius for snow use, where it's primarily used below 6mph. It did say that it helps out with some punch, but at 5kw it's half the power of the IMA motor. Also considering the Prius AWD just arrived at our shores makes it not really affordable option I would think, although I could be wrong.
Last edited by Sigma Projects; 06-11-2019 at 10:25 PM. Reason: Prius rear electric motor
Old 06-11-2019, 11:01 PM   #7 (permalink)
The Prius MGR is induction meaning that much greater power than rated at much lower voltages are possible especially if you actively cool
The MGR for the Prius is actually small enough it could fit under an Insight
The highlander unit is quite large by comparison, uses PM and thus requires high voltages to spin at any rate of speed.
You canít overclock a PM motor the way you can with an induction motor tweaking its field .
Although the larger MGR is quite capable integration into the body will be more difficult
Old 06-11-2019, 11:13 PM   #8 (permalink)
For my purposes I want to be able to move the Insight roughly 25mph on pure electricity for a very short distance. Do you think that would be possible with the Prius induction motor?
Toyota has mentioned that the Highlander Hybrid's EV mode can go roughly 5 miles while traveling below 25mph.
I don't mind removing the spare tire to mount the electric motor, my main concern is if it can move the car to a speed anywhere near 25mph.
Also maybe you can help me understand something. While I was reading through the ecomodder post everyone mentioned how it's extremely difficult to get the 650v output to the motor and only mentioned achieving high volts by utilizing more batteries. But when I look at the Highlander Hybrid specs the battery is 288v and they have an inverter (sorry if wrong terminology) to output up to 650v AC. Wouldn't that be the route to power the MGR?
Old 06-12-2019, 07:12 AM   #9 (permalink)
A step up inverter is a complex way of controlling a motor , the folks who run a Nissan Leaf Motor in a conversion rarely run anywhere near its rated voltage
Some on diyelectriccar are developing control boards to allow the use of the OEM inverter but things get complicated from there.
As for the highlanders EV mode it isn’t drive by the mgr but rather the primary motor up front, the mgr kicks in as needed when wheelspin is detected.
I would make a thread on diyelectriccar asking on the mgr, until someone does it for real , gets weights and other measures of the motors we won’t know the real capabilities of either
Hmm
Old 06-12-2019, 12:40 PM   #10 (permalink)
Ah good point about the EV Mode.
At least from what was shown in the forum post you shared the RPMs the MGR was reaching with the voltages shown in the video are promising.
Ah ok, thanks for explaining about the inverter difficulties.
Physical measurements have been taken of the unit.
I guess if no one on the various EV sites have successfully utilize the MRG unit then it's probably not viable at the moment.
Location (Required)
Where you live
