48.8 lifetime MPG after 150,000 miles. - Insight Central: Honda Insight Forum
Go Back   Insight Central: Honda Insight Forum > 1st Generation Honda Insight Forum > MPG Issues
Old 11-05-2014, 03:18 AM   #1 (permalink)
Fox
Default 48.8 lifetime MPG after 150,000 miles.
Car seems to have a power issue pre 2200 rpm or so. What should I be checking in order of most common problem. I drive it slow doing the pedal to metal to 3k Roma then shift and downshift/regin down hills. I've grid charged balanced the pack and cleaned the egr plate, still bucks pretty bad in 1st gear. Thanks for assistance as I've read til my eyes bleed.
Fox is offline   Reply With Quote Quick reply to this message
Old 11-05-2014, 07:02 AM   #2 (permalink)
Premium Member
Balto's Avatar
When was the last time you replaced the spark plugs? Are they torqued to the proper spec? Maybe one of your o2 sensors are going bad, EGR itself going bad, or in rare cases, a clogged catalytic converter. I wouldn't even look at the cat until everything else is checked first though.
Balto is offline   Reply With Quote Quick reply to this message
Old 11-05-2014, 09:52 AM   #3 (permalink)
Fox
Spark plugs 6 months ago. Car seems to run much better when it hasn't warmed up yet and takes forever to get to an autostop point because of it?
Old 11-05-2014, 01:34 PM   #4 (permalink)
Willie Williford's Avatar
My theory:
Pedal to the metal,(even to 3K) and high regen will eat the MPG.
Try driving like you had an egg on the gas pedal.
Use: 438,000 mi. @ 58.2 LMPG.
Old 11-05-2014, 04:01 PM   #5 (permalink)
Fox
Which is counter to what many claim on ecomodder and many other places. They say throttle opening = less pumping losses as long as you shift at 3k or below. I think I agree with you. As to how to test my oxygen sensor, I'm at a loss.
Old 11-05-2014, 04:14 PM   #6 (permalink)
Have you tried disconnecting the EGR valve, and driving it for a while?
I assume you mean bucking at 2200 rpm in 5th?
Old 11-05-2014, 04:34 PM   #7 (permalink)
Fox
the bucking is happening in all gears including 1st. If the engine is cold it runs fine.
Have not tried disconnecting it but that is good idea if that works does it mean EGR bad?
Old 11-05-2014, 04:38 PM   #8 (permalink)
Maybe. Is your temperature sensor behind the grill still functioning?
EGR functions with low throttle opening and low rpm.
Also check for vac. leaks, especially the hose going to the MAP sensor (The hose on the small pipe) drivers side behind the end of the engine.
Old 11-05-2014, 05:04 PM   #9 (permalink)
Fox
Also, how long should the 2ndary starter take for it to bypass hybrid starting? if my HV battery is off it takes a good 7 to 10 seconds and then sometimes it just makes a bunch of clicking sounds possibly trying to start the car on the 3rd phase of this 21second to 30 second process(see my math?)
Not sure if this is suppose to happen or not?
How Would I test the Temp sensor?
Old 11-08-2014, 12:14 PM   #10 (permalink)
Fox
Ended up helping tremendously by replacing my egr with accord 2001 egr valve! Yay. Now have to fix other quarks, like engine cutout at 30mph then autostop restarting after gear in, maybe it's good lol
Location (Required)
Where you live
