2018 Wiper flop/slap/issue thread - Insight Central: Honda Insight Forum
Old 01-13-2019, 10:15 PM   #1 (permalink)
Default 2018 Wiper flop/slap/issue thread
*Update 1: Prior to doing this, look at post #8 (KLR3CYL). He notes some clearer/better options.
Here is a thread on if you have an issue with the wipers flopping and extending too far on the high speed. On my car, the driver's wiper would "slap" the post going to the roof and the plastic vent cover by the hood.
Steps to fix:
1. Remove wipers - Using a 14mm wrench/socket, remove the nuts holding them down. Try to pry. For me, I put the nut back on a few threads and SLIGHTLY tapped on it while prying on the bottom with a flat head.
2. Remove the plastic cover - This is simply done by prying the it loose. Some tabs may break in the process. I had good luck with a screw driver. The tabs on the bottom are part of the rubber seal (just above the battery).
Horn12007 is offline   Reply With Quote Quick reply to this message
Old 01-13-2019, 10:25 PM   #2 (permalink)
3. Now, you have access to the wiper linkage arms. From reading others' posts, it seems that the common wear area is bushing just under my hand (where the arrow is). You can simply pop that off with force. It is a ball and socket type connection.
Just underneath the circle is the other end that needs to be pushed down (popped out of the ball using tools like screwdrivers or whatever else you need). From there, you can just replace the bushing. For me, I bought a bushing kit that I "thought" would work. I had to rig it and plan on getting the right bushing later on. My old bushing was shot and there was so much slop.
4. Here you can see where the bushing is broken.
Old 01-13-2019, 10:34 PM   #3 (permalink)
5. I actually took the rest of the linkage off as one. This may or may not be necessary for your vehicle. Again, the main issue, to my understanding is "usually" just that 1 bushing, but it's good to inspect the rest.
6. Taking the rest apart just requires a 10mm socket. Nothing special. Remove the longer "plate" as I call it. It has 6 bolts. Those bolts also hold in the individual shafts (for lack of a better term) to the car itself. Everything will now be loose and you can snake it out.
*Before removing the 6 bolts, there are 2 plastic/rubber covers that need to be remove. Penetrating oil and twisting it helps remove them.
Old 01-13-2019, 10:37 PM   #4 (permalink)
7. After removing it all and inspecting the bushings, driver and passenger shafts, I notice they were "sloppy" due to the clips/rings not being seated. I just pushed them back and used pliers to make sure they were tight again.
Old 01-13-2019, 10:44 PM   #5 (permalink)
8. After you have replaced the bushing, greased it, and completed everything, you can put it all back together in reverse order.
9. For me, the kit I bought didn't have a good fitting bushing, so I ended up using a dremel, making a notch and trying some wire. I then put a zip tie on it and it fit tight. You can save yourself the hassle by getting the right bushing. I plan on getting the right one if I can find it.
10. This kit pictured was the one I bought that didn't have a great fitting bushing. As of right now, it is working for me with my rigging. A lot better and it has fixed the flop/slap.
Hopefully this will help some new members. I'm sure there are different ways to do this. Just a general idea.
Old 01-14-2019, 06:57 PM   #6 (permalink)
eq1
I replaced those bushings before. FYI, I found some alternatives to OEM at NAPA that more or less work. As I recall, it might've been a little tight fitting them into the arm holes, or fitting the ball joint into the bushing, or something, I forget exactly. But they work. They're called "wiper linkage bushings," the part number is 675-1596. The box says they're for a Nissan.
2000MT, CANADIAN
Old 01-14-2019, 08:39 PM   #7 (permalink)
Thank you for this info!
Old 01-15-2019, 12:11 AM   #8 (permalink)
Thank you for posting.
A couple of comments:
Iíve never had to use a hammer to remove a wiper arm on an Insight. I take off the 14mm nut and then lift it up, like you are going to clean the glass, then just tug up and down and it seems to just pop off the tapered splined shaft.
Second, Iíve removed the cowl vet panel on a number of Insights. I use a forked clip pry tool to spread the pressure when popping the clips. I only pry from the engine compartment side. I would never try to pry or slide a tool in from the windshield side, if you lean wrong or pry putting pressure on the lower part of the glass you may break your windshield.
Scott
Silver 2000, MT 160,000mi, RE92's, S2000 leather steering wheel
Silver 2002,CVT 187,000mi
Blue 2002,MT 126,000mi, RE92's, S2000 leather steering wheel
Red 2002,MT 196,000mi, RE92's, new rear springs, GAZ shocks
Citrus 2000,MT 182,000mi, MIMA, RE92's, S2000 leather steering wheel, Japanese seat covers.
Simple grid charger SC03
New rear coil springs available, PM me.
One piece aluminum underbody panels.
PayPal:
KLR3CYL is offline   Reply With Quote Quick reply to this message
Old 01-15-2019, 12:50 AM   #9 (permalink)
Scott
Yeah, I was pulling up as I pried. I wasn't prying hard. Should have put that in the post. Pry tools would be nice.
For some reason, my wipers were very tight on the splines even while pulling up on the wiper. There was some rust and things like that.
I agree your tips are better than mine. I'll update it later.
Old 01-22-2019, 04:15 PM   #10 (permalink)
The wipers on my car were juddering badly, andI found the spindle bushes had a lot of wear, although the circlips were in place. The spindles were swollen from rust. The bushes push out fairly easily, and new nylon cylindrical bushes and cleaning up the spindles seem to have cured the juddering.
velosolex50 is offline   Reply With Quote Quick reply to this message
