2001 w/CVT still won't move - Insight Central: Honda Insight Forum
Old 03-03-2019, 06:28 AM   #1 (permalink)
Default 2001 w/CVT still won't move
My 2001 w/CVT (156k miles) that I hardly ever drive but I keep it running and charged up, will go into gear, (drive and reverse and you can feel it going into the gear) but for some reason the car won't move at all in either direction. I jacked up the car and in neutral neither of the front tires would spin so i'm guessing that indicates a problem. I've posted on here before and some suggested that it's the flywheel in the transmission that needs to be replaced but before I do that, i'd like some more opinions if anyone has any to offer. Thank you for your efforts
dlfoster is offline   Reply With Quote Quick reply to this message
Old 03-03-2019, 11:52 AM   #2 (permalink)
Willie Williford's Avatar
There have been reports of the cable/fitting breaking (on top of the trans.)
Use: 438,000 mi. @ 58.2 LMPG.
Old 03-03-2019, 01:50 PM   #3 (permalink)
do you possibly have a picture or a description of what it is i'd be looking for in finding this cable/fitting?
Old 03-03-2019, 02:32 PM   #4 (permalink)
Search "broken shifter cable" there are a few.
I can't post pics, sorry.
Lets see if this works:
https://www.insightcentral.net/forum...cable-fix.html
Old 03-03-2019, 02:52 PM   #5 (permalink)
Rainsux's Avatar
I'm betting on stripped flywheel splines.
Sam
2000 Citrus
Custom Turbocharger System
MIMA #150
BumbleBee Battery
OBDIIC&C Gauge
NM license plate KERS
Alpine Stereo
GAZ rear shocks
2002 Blue getting new engine
Old 03-03-2019, 03:02 PM   #6 (permalink)
seeing that you aren't the only one to suggest this now and in the past i'll take it that you are most likely right. Could a flywheel really go bad from a car that is hardly ever driven or is it just going to go bad whenever and however it feels like it?
Old 03-03-2019, 03:11 PM   #7 (permalink)
Is there a better way to drive so the fly wheel does not strip out.like never have the lead foot . Or just drive downhill everywhere. ?
NathanC is offline   Reply With Quote Quick reply to this message
Old 03-03-2019, 07:27 PM   #8 (permalink)
Rainsux's Avatar
This is just a theory. Somebody correct me if you have a better explanation.
I doubt if it has anything to do with how you drive your CVT. I think the input shaft is made of a harder material than the flywheel. The very slight movement between the parts causes the input shaft to "eat away" the flywheel splines. It is put together with grease, but the rubber o-ring that keeps the grease in fails, and then you have metal-to-metal, accelerating the failure.
Sam
2000 Citrus
MIMA #150
BumbleBee Battery
OBDIIC&C Gauge
Alpine Stereo
GAZ rear shocks
Tags
2001, cvt
Similar Threads
2001 honda insight transmission - goes into gear but won't move dlfoster Problems and Troubleshooting 6 01-12-2019 06:30 PM
2001 Insight CVT 248k $2600 Souix Fall,SD Foos Buy/Sell Insight-Related Items 0 01-27-2014 02:10 PM
Yellow 2001 CVT in California Need4Speed eBay Auctions: Honda Insight related 5 03-01-2012 05:42 PM
2001 vs 2004 exhaust comparison - PICS jeff652 Modifications and Technical Issues 3 11-14-2011 03:02 PM
