Voltage jumping between 14.X and 12.X on drive to work this morning - Page 2 - Insight Central: Honda Insight Forum
Old 06-19-2019, 12:02 PM   #11 (permalink)
Willie Williford's Avatar
Have your 12 V battery "load" tested. It take app. 10.2V to actuate the IMA system for starting.
Use: 438,000 mi. @ 58.2 LMPG.
Old 06-19-2019, 12:18 PM   #12 (permalink)
I'll test it after work. It's only a year old though.
mike103192 is offline   Reply With Quote Quick reply to this message
Old 06-19-2019, 03:18 PM   #13 (permalink)
Mario's Avatar
Check all your ground straps, too.
Mario is offline   Reply With Quote Quick reply to this message
Old 06-21-2019, 09:31 AM   #14 (permalink)
So my battery tested good (12.86v @ 588 cca). The ground cables look good as well. There is definitely something going on though. On my drive from work yesterday, while moving, my car quite motor assist, Regen braking, and autostop. No I'ma light. I took my key out, put it back in, everything is good again and drove normal for another hour. Something has to be intermittently failing, but what????
Old 06-21-2019, 12:57 PM   #15 (permalink)
Untill you get an IMA light you are not going to figure it out. The IMA error code reading will point you in the right direction.
I say it again, the IMA has a brain of its own.
