2010 cd player error - Insight Central: Honda Insight Forum
Old 03-30-2017, 12:38 AM   #1 (permalink)
Default 2010 cd player error
Today, the CD player in my 2010 Insight (without navigation) decided to: a) not play any cd's it provides the following error for all discs:
<BAD DISK> <BUSY PLEASE WAIT> <CHECK USER MANUAL> <PRESS EJECT BUTTON>
The manual says its a mechanical issue when this error comes up.
Any solutions?
Thanks!
photosenior is offline   Reply With Quote Quick reply to this message
Old 03-30-2017, 05:41 AM   #2 (permalink)
gms24ru's Avatar
Maybe optical lens need to clean.
Are you use CD-cleaner-disk?
Don't know it's name, CD with brushes.
If when you insert the disc there is no sound of the acceleration of the motor, then the motor died.
It can be replaced by another motor such as from computer CD-ROM. I fix DVD-player with similar problem.
Honda Insight II 2010 RHD Silver G-Edition Japan
Electric Train H710MK124RU Japan-Krasnoyarsk
Telegram:
gms24ru is offline   Reply With Quote Quick reply to this message
Old 03-30-2017, 12:05 PM   #3 (permalink)
Is there a CD in there? Perhaps a homemade one with a sticky label?
That was the issue I found on a different Honda. Best to use a sharpie to label disks.
Also, a common problem on another Honda forum is that little kids will put coins into the CD slot.
Either way, you are going to need to remove the unit and take it apart to clean out the issue. I think if you look down in the Modification section there is probably instructions for removing the unit. Don't forget to find the radio code first.
If it is just broken, eBay is a good place to find replacements.
Old 03-31-2017, 09:48 PM   #4 (permalink)
Thanks for the thoughts. There is no disk in there. Every disk I try it doesn't engage into the play mode just trys and ejects the disk quickly. I dont think its spinning the disk just ejecting, thus no luck with the cd lens cleaning disk.
Anyone have a link to instructions on replacing? How hard is it?
Old 04-01-2017, 01:46 AM   #5 (permalink)
https://www.insightcentral.net/forums...ock-radio.html
Old 04-03-2017, 01:17 AM   #6 (permalink)
Thanks for the link!
Has this happened to anyone? I'm wondering what part I'd need to replace.
If I dint have to replace the whole interface that would be bueno...
Thanks again!
Old 04-03-2017, 02:09 AM   #7 (permalink)
gms24ru's Avatar
If you are not able to fix take it to service.
If you can DIY, then disassembled the case and connecting 12V you will understand the cause of the fault.
Write on the forum, will help possible.
Telegram:
Location (Required)
Where you live
