2012 Insight might be dead? - Insight Central: Honda Insight Forum
Old 10-21-2015, 01:31 PM   #1 (permalink)
Default 2012 Insight might be dead?
Hey everyone!
I'm the owner of a 2012 Insight and I really have enjoyed driving this car. I bought it for two reasons . . . . .ok three. 1) It's a Honda. Enough said. 2) I wanted something that got better than 35mpg and I was consistently averaging 49-51 when hypermiling. 3) No way in hell was I gonna be a prius owner lol.
History: Bought car with around 155k miles on it. It was towed behind an RV most it's life and it was in immaculate condition with very minor wear. Bought it for around $9,500 in March of this year. Not long after I bought, I noticed little puffs of smoke after I was coasting down a hill, came to a stop, and then gave it throttle to accelerate. Did some research and found that this motor has a ring problem allowing oil to get into the combustion chamber, hence the smoke. So Since then I've carried a funnel and a 5 quart jug of Mobil 1 0w20 (I work for ExxonMobil) in the car to top it off. Fast forward to Wednesday last week. I'm going up a hill doing 64mph when I notice that I'm all of the sudden decelerating and losing power. Pull off to side of road and the car stalls out. The dash shoots me a slew of error codes. The ones I can remember are as follows - Check emission system, check brake system, check hill climb system, check tpm system, check vsa system. Absolutely NO check IMA system. Get towed home. It was showing symptoms of a bad battery because I would try to restart it and lights were getting dim and eventually just got a "click". Got battery tested and they said it was on the last 25% of it's life and it "may or may not start your vehicle in cold or hot conditions". So I bought a battery. Installed it and car starts with the smooth idle for a second, maybe two then idles rough at about 500 rpm and I have absolutely no throttle response when pressing on the gas pedal. Called Honda and with the symptoms I described they said it sounds like my IMA system is bad and the estimate is $2,500-$3,500 too fix. Again, no error code in regards to the IMA has shown up on my dash.
So, has anyone experienced this? I'm concerned because this is my commuter car. I drive 80 miles a day minimum to and from work. I read a post just doing a google search of some guy who experienced almost identical symptoms and he said he was told that oil fouled up the spark plug and that a ring job was in order.
I'm considering two things. I'll either pay to fix it or fix it myself, but I've never worked on this new of an engine. I'm not worried to, it's just I don't know if these engines are more finicky with all the electrical technologies linked to it. I'd love to get all your guys' input. I'm a firm believer in car forums as they've helped me learn about the cars I've owned and saved me lots of money.
Thanks,
BJ
caliber1 is offline   Reply With Quote Quick reply to this message
Old 10-21-2015, 02:32 PM   #2 (permalink)
olrowdy01's Avatar
Originally Posted by caliber1 View Post
Hey everyone!
Welcome to the forum.
Perhaps try a heavier grade oil to slow the usage down.
If it was a G1 we would say check the 12V ground cables if the dash makes like a xmass tree.
Does the dash still go nuts after changing the 12v battery?
Ahh yes, the ol', "You need the expensive battery changed." The dealers make a nice profit changing IMA batteries. If you don't get a specific IMA bat error code look elsewhere for the problem.
That sounds more reasonable but I'd get the car to continue to run first since it idles OK.
Thanks,
BJ
Check the fuel pressure with a gage. The pressure should be around 40 to 45 psi.
When you first turn the key ON the fuel pump is supposed to run for ~2 seconds to build up fuel pressure and then it turns OFF until you actually start the engine. If it is very quiet outside you might be able to hear the pump run for those 2 seconds and then stop. That's normal.
If the fuel pump doesn't start running again when you crank the engine it will start and idle but die within 5 seconds or so (as you describe). With a fuel pressure gage on the fuel line near the injectors you will be able to see if the pressure remains normal when the engine starts.
It's possible that you have a badly clogged fuel filter but depending on where the filter is in the system in relation to where a fuel pressure gage would be attached it may not show up on the gage.
[edit] It's also possible that the pump only runs while you have the key turned to the Start position. I don't have a G2 schematic so I can't look up the wiring of the car.[/edit]
If the pressure doesn't remain around 43 psi you probably have some sort of electrical problem, a clogged fuel filter or a bad pump. So check the fuel pressure first.
Try to avoid the dealer. If you can get the car to run, some of the auto parts places will read the OBDII codes for free.
2005 Insight, MT, 88K, Silver
1988 Honda CRX HF, 44/51 mpg
1963 Lotus 7 replica, 12 mpg
My website
* Hack your OBDIIc&c
* Cool the IMA battery
* DIY Fix rear motor mount
* DIY Grid charger/discharger build instructions etc
* My grid charger/discharger thread on the forum
Last edited by olrowdy01; 10-21-2015 at 07:56 PM. Reason: Add additional pump info
olrowdy01 is offline   Reply With Quote Quick reply to this message
Old 10-21-2015, 02:40 PM   #3 (permalink)
PatJr's Avatar
Hummm, electrical motor making the gas engine smoke ...? Doesn't seem to add up to me but been wrong before. Can you turn the IMA system off like in the gen 1 and try the car out?
I'd start with a compression test. I'm kinda old school, what with being old and all. Tossing out a blind guess, timing chain jumped.
== the fuel thing sounds like a good idea ==
PatJr is offline   Reply With Quote Quick reply to this message
Old 10-21-2015, 03:37 PM   #4 (permalink)
Thank you so much for the replies fellas.
This is my first hybrid so I'm not familiar with them very much. However, my got also tells me it's not the IMA. When I bought it from another dealer the tech said it's basically brand new because it never got used being towed behind an RV. IDK.
I've got a scan gauge but it throws a code c1555 which from what I've researched it just means the scangauge knows somethings wrong but not sophisticated enough to identify it. I'll check the spark plugs and fuel pressure later. Can you point in the direction of how to do a fuel pressure test?
BJ
Old 10-21-2015, 05:19 PM   #5 (permalink)
Sounds like a bad starter battery.
+1 on using heavier oil.
Old 10-21-2015, 06:07 PM   #6 (permalink)
RedDevil's Avatar
Even the replacement battery may be bad, he said while grinding his teeth...
Check the voltage, best of all keep a tool around to show 12V battery voltage at all times.
I set up my UltraGauge to always display battery voltage, so I know my battery is bad but not dead yet.
2011 Insight Elegance
Accord horn, Waxoyl, HIDs, Green Oil, UltraGauge, LEDs, full upper&partial lower grille block, aero tweeks, plans for several eco mods
RedDevil is offline   Reply With Quote Quick reply to this message
Old 10-22-2015, 12:50 AM   #7 (permalink)
Hey Cobb! Is the starter battery different from the battery I just bought? I've also heard that these don't have a altnernator but instead a dc-dc converter.
BJ
Old 10-22-2015, 01:06 AM   #8 (permalink)
Correct, no alternator. The IMA system has a converter that charges the starter battery.
Yes, you can buy a bad starter battery too. I use to work at Sears and ours were only charged to 80% from the factory. If you have a battery charger Id use it over nite on yours or go back to the place and have them check it. Even a good testing starter battery can cause all the idiot lights to come on like you said.
The code you gave online shows it could be a loose gas cap to a bad cat. You may need to visit an auto parts store to get them to read your code or even a Honda dealer.
https://www.insightcentral.net/forums...1555-code.html
Scangauge read CEL (MIL) Code C1555 [Archive] - CleanMPG Forums
We have only 1 post here if I recall correctly of a guy who had a bad IMA battery. To get an error code the usable capacity is typically below 10% of the original capacity. An aftermarket battery is like 2 grand.
Old 10-22-2015, 01:16 AM   #9 (permalink)
The 2012 insights have a known piston ring issue. Sadly, because of the high miles I doubt Honda will help you with this as they are with the owners that have reasonable miles for the age. I guess this Insight was towed four down and therefore the high miles? How many miles have you put on it? I doubt it needs any IMA work. But it does need the ring job Honda has been doing to it's siblings. I bet it would still be a fine car with that work done, but it may be hard to justify the cost considering the miles and therefore the value.
Sent from AutoGuide.com Free App
Old 10-22-2015, 07:31 AM   #10 (permalink)
Default should i bring my car to dealer?
j have a 2012 insight, i have 20k miles on it, do you all think i should bring my car in the honda shop and ask them about this piston ring issue with my car? i just dont want my car to have this problem? i plan on getting all my oil changes done and any service at the dealer.
themadchef is offline   Reply With Quote Quick reply to this message
