2011 major loss of power - Insight Central: Honda Insight Forum
Old 05-29-2016, 12:03 AM   #1 (permalink)
Default 2011 major loss of power
Hi guys, the car has 85k miles on it and suddenly the car lost power and idle became extremely rough, losing power. Got misfire codes pulled. The car will start from a cold with hardly any issues but after one minute the car loses power again.
Pulled plugs and found cylinder #2 was wet. So I replaced all the plugs and ordered two new ignition coils but the problem persists. Seems actually worse now.... Help!!
Danno is offline   Reply With Quote Quick reply to this message
Old 05-29-2016, 12:28 AM   #2 (permalink)
samwichse's Avatar
Possibly a map sensor problem? Does it continue to give misfire codes?
Old 05-29-2016, 12:49 AM   #3 (permalink)
Yes, still misfire codes.
Old 05-29-2016, 10:04 PM   #4 (permalink)
You need to do a compression test. It maybe that damn oil consumption rearing its ugly head. Was the plug black, oily or just gassy?
Old 02-24-2019, 10:53 PM   #5 (permalink)
Was this problem ever resolved? I am having pretty much identical issues with a 2013.
The car lost power while driving on the interstate (!!!) and engine runs super rough. Lots of scary info messages such as "check emission system" "check brake system" "check vsa system" and "check hill start assist system".
Much to my frustration, I found the car was very low on oil. Had to put in ~1.5 qts to bring it back to safe area... I have done the oil changes for the 2 years we have had the car, and to my knowledge hasn't consumed much oil between changes...until now apparently.
Pulled plugs and the ones on cylinder 2 were really really bad and cyl 3 not so horrible but not great either. I replaced spark plugs, and got access to a code reader (my cheap one doesn't seem to work..) and the codes are p0300, 0302, & 0303. Which is understandable considering the shape those plugs were in. Another observation: There is some lovely black sooty crud that appears to have come out of my exhaust lately. Do I run the risk of breaking exhaust stuff like c02 sensors, catalytic, etc? Have I already broken something else? Ooof.
Let me know if you all have any suggestions, or OP what your prognosis was.
Thanks
henmill is offline   Reply With Quote Quick reply to this message
Old 02-26-2019, 03:33 PM   #6 (permalink)
Thanks
There is a service bulletin on your model year Insight. The dealer will tear the engine down and replace the piston rings. I hope you saved the fouled plugs. We have several threads around here about this. Here is a link to the TSB:
https://honda.oemdtc.com/TSB/A16-101.pdf
Old 02-26-2019, 04:09 PM   #7 (permalink)
Thanks for the link egads. I did not know Honda had extended their coverage for this. I do still have the plugs, posting them here just because.. I have definitely read a lot of stories on this issue on this forum, but it sounded like people got mixed results from dealers whether they would fix or not. This eases my mind greatly. Time to call up the dealer
edit: picture doesn't seem to work. oh well. you get the idea, a shredded spark plug
Old 02-28-2019, 11:00 AM   #8 (permalink)
UPDATE: the dealer called me back with grim news. Says a new motor is needed and Honda won't cover any cost because I changed spark plugs. Quoted $3300 for a used engine with 81k on it. Yeah. ok. New engine quoted >$8000.
Guess who's going to cause a scene this afternoon at the dealer?
Sorry for hijacking this thread, but I thought others in my situation down the road may find this info useful.
Feel free to give any advice on my best options. I.e., legal recourse.
Old 02-28-2019, 11:42 AM   #9 (permalink)
jcbesq's Avatar
Causing a scene at the dealer wont accomplish anything as corporate honda makes the ultimate decision to pay up ... they can however be a good advocate for you ... it all depends if pressure or cajoling will work on them ... you could also try getting a lawyer to draft a strong letter on official letterhead to corporate honda offices ... include all service documentation, when the problem began, when you changed the plugs and why, pictures of the plugs would help too, some print outs of insight central threads re the oil consumption issue, etc ... best
JB
2011 Insight LX - 78k miles
jcbesq is offline   Reply With Quote Quick reply to this message
Old 02-28-2019, 12:24 PM   #10 (permalink)
Willie Williford's Avatar
Henmill:
If you can't get a satisfactory reply at the dealer, contact corporation headquarters.
Use: 438,000 mi. @ 58.2 LMPG.
